Televison & Video Logo
Question about Seiki Televison & Video
Remote control not working
Remote quit working...TV less than 1 yr old...changed batteries, etc. Seiki sent me a new one. TV not responding to it at all...tried new batteries, unplugging/resetting, etc. What am I missing?
Posted by Renae Yates on
  • 7 more comments
  • Anonymous Mar 11, 2014
    vertical lines on copies but not on printed pages
    overdrive is slipping
    Have a manual for 2009 Daihatsu Trevis automatic?
    I need to replace the oil pump on my 2000 dodge grand caravan.I had the motor replaced recently and am not sure the same year motor was install led.I now have to replace the oil pump and am not sure which one to buy
    K7.85 won't run after the trigger is released have to turn power off and back on
    wont fill
    When downloading the recovery disks it freezes on Office 2010.
    suzuki swift immobilizer loght is flashing car wont start
    1988 ford f250 has spark & fuel pressure but wont start
kathy
    New Friend:
What do I do when 1 station is in Spanish and 1 is being narrated while all others work in English and not narrated
Posted on Sep 01, 2016
Anonymous
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
Maybe have to program the remote for your specific model if the controller they sent you is a generic one. Google remote codes and your make model.Try newer batteries and make sure they're the right way round. Sorry for being patronising but you know what people are like. Never sure who's asking.
Posted on Jun 24, 2012
5 Related Answers
SOURCE: The TV will not respond to the remote and
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
You need to do some diagnosis to confirm the source of the problem.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Posted on Nov 28, 2011
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: TV doesn't respond to the remote control...can't change channels
You have to find out if the remote is sending out the infrared signal to the TV remote receiver or not, you can test that by pointing the remote at the digital camera, you should see flashing light on the camera screen when any one of the remote button is pushed (digital camera can detect infrared light). If get the flashing light then the problem is in the TV remote sensor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 15, 2010
Anonymous
SOURCE: remote code for Seiki TV 32"
The 4 digit code 0060 worked for me with a comcast remote - light gray remote with dark grey OK button. this was on a Seiki 22' LCD TV. I programmed the TV control on the comcast remote first by using 0000 (remote blinked twice accepting the code) then using 0060 (blinked twice again). This code seems to work. Not sure if the sequence or combination is actually needed.
Posted on Jan 20, 2011
Anonymous
  • 211 Answers
SOURCE: I can't turn off my TV
Maybe your logic-board is a little stressed.
If your TV doesn't response on your remote control, the only way to switch off is to unplug it.
After one minut you can plug it in and give it a try, no problem.
If it still doesn't work, you have to visit your dealer.
Kind regards,
Gerard
Posted on Nov 21, 2008
dnewcombe1
Dana Newcombe
  • 1564 Answers
SOURCE: remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Posted on Jul 24, 2009
What do I do to get Seiki remote control working after replacing batteries, making sure was well within range of tv with nothing blocking tv?
Try their site on the internet, many have chat to get live customer service, or call the tech support line. Most likely need a new remote. Cheaper to buy a universal remote at Wal Mart and program it to your TV
1helpful
3answers
What is the sky remote code for a Seiki TV
Firstly you need to check if the sky remote is rev10 or later. Anything less will not work.
The code is 2992 or 3992.
My remote is rev10 and code 2992 worked.
Hello, My tv is not responding to the remote. Cannot change channels or do anything with TV because of this. TV is a month old
solution 1: try pushing the buttons on the tv, manually, and if that doesnt work, call someone to look at it, like a handyman or geeksquad
solution 2: change the batteries in the remote
2helpful
2answers
I was watching T.V. and when I went to change the channel, the remote control wouldn't respond. I changed the batteries (generic) & the new ones didn't make the remote work either. I hit the power...
You won't be able to see the light from remote's LED (Light Emitting Diode) because it is IR (Infra Red) which is invisible to the human eye.
Try re-entering the code for your tv to see if it works.
If that doesn't work, the remote might have just died. It happens.
Get yourself a new UNIVERSAL REMOTE for less than $20 and just program it for your tv.
Good luck and post back to let us know how it works out.
My dish remote for my new vizio tv only works part-time. the volume and power work, but the guide button only works less than half the time and only after holding it down for 5 seconds. i have exchanged...
judileighahl,
If you have replaced batteries and had a new remote sent out to you, either the Vizio TV is emitting an IR signal that is interfering with the remote IR signal to the receiver. To test if the TV is emitting interference, is it possible for you to turn the receiver in a direction away from the TV and see if the remote will work? If it does work after moving the receiver, that indicates interference from the TV. If it doesn't change the situation, you might check for other interference from other components (florescent lights, etc.). I hope this helps.
Ray Calo
DISH Network - Executive Offices
Remote control not working on brand new series 4 42 inch samsung
2answers
I need a remote control
well this is a tv remote, and you cannot use a universal remote for this. maybe the tv has buttons marked"tv/video" dat youll have to press manually if not then try to get manufactr replaced remote dat came with tv
Top Seiki Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
rhodesworks
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
