Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
J
Joan Mitchell Posted on Dec 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get to the belt on shark navigator nvl22
Can't get it open
Dennis Key
Level 3:
  • Master 2,481 Answers
  • Posted on Mar 12, 2017
Dennis Key
Master
Level 3:
Answers
2481
Questions
Helped
750816
Points
6126
Go the back to company there replace the head free
1 Related Answer
Anonymous
  • Posted on Jun 03, 2012
SOURCE: shark navigator. How do you get to the belt?
in addition to the obvious screws, and two under the main coaster wheels, there are 2 hidden under the 2 mini wheels up front. pop them out and remove.
this voids any warenty i think
2answers
My shark navigator s belt won't stay on
That is nearly always caused by having the 's-twist' going the wrong way. When running it should be pulling the belt onto the spindle.
https://www.google.com/search?q=Shark+Navigator+replace+belt
Why wont the roller brush turn on my navigator shark NV22L
It could be a bad switch or brush roll motor, a broken belt, loose wire or contact. You must inspect and test all these areas to narrow down the cause.
Why does the brush roller work for a second, then stop?
could be a loose belt or brushroll endcaps need to be cleaned
after you check this if it still cuts out its the electronic board
sorry not repairable
here is the belt if you need it Vacuum Belts Shark Navigator vacuums Lift Away Motorized Floor Brush NV350...
1helpful
2answers
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
How to replace belt on shark navigator
Call Shark cust. service. They should send you a new head
1helpful
Powered rollers wont spin.
1) test the belt for worn or broken
2) power rollers bearing defective test and repair
3) motor need repair.
4) test the thermal fuse
5) test the main switch for open or defectie.
se the diagram
3helpful
Shark navigator. How do you get to the belt?
1helpful
2answers
My beater brush comes on for 3 seconds and quits working on my shark navigator.
Same thing with my NAV22. Called them. They walked me through some troubleshooting and then they offered to send me a replacement power floor nozzle (the entire bottom piece). They said they don't want us to open it up to replace belts, so if you registered the product when you bought and it's been less than 5 years you should be all set...
Top Euro-Pro Vacuums Experts
ZJ Limited
ZJ Limited
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
