20 Most Recent Shark Helmet NV22L Shark Navigator Upright Bagless Vacuum Questions & Answers
Hair in bearings and things wrapped around roller
Shark Helmet... | Answered on May 11, 2019
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Shark Helmet... | Answered on Jan 15, 2017
You call the company and ask them.
Don't be so lazy, and rely on others.
Shark Helmet... | Answered on Nov 28, 2015
Did you try the Shark website?
http://www.sharkclean.com/support/parts-accessories/11/vacuums/
Shark Helmet... | Answered on Feb 10, 2015
The hair in the bearings. I take pair of needel nose peirs. Its hard,but it only i found
Shark Helmet... | Answered on Dec 01, 2014
Call cust. service to register
Shark Helmet... | Answered on Nov 29, 2014
Call Shark cust. service. They should send you a new head
Call shark cust. service. They can help you. May send you a new one.
Do nothing. Call shark cust. service. They should send you a new part.
Shark Helmet... | Answered on Oct 19, 2014
Greetings Georgiana,
If you stand in front of the vacuum you will see the red button that you use to start it. On the opposite side (on the left of the red button) you will see a round grey/silver button. Grab the handle at the top of the canister that holds the dirt with on hand and press the grey/silver button at the same time pull the canister away from the vacuum.
There is a button in the front of the canister that releases the trap door at the bottom. Make sure you have it over your trash can when you push that button.
As you can see I just used mine and haven't had a chance to clean it yet! Sorry about that but I figured I get this to as soon as I could!
I hope this helps! :-) a906ac6d-dc2e-416c-b1c0-3603fdb998e9.jpg 3c0114c0-5922-4439-a9dd-1f57a2528b93.jpg 6cc600a6-72a8-4be3-acdd-8bc4e6fead96.jpg
Shark Helmet... | Answered on May 30, 2014
http://www.sharkclean.com/cgi-bin/livew/site.w?location=b2c/product-registration.w&target=main&frames=no&sponsor=000006 This is Shark Clean registration page
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Shark Helmet... | Answered on May 29, 2014
Not sure if that warranty is by Sharkclean or if it was an extended warranty where you purchased the vacuum but Shark's product registration page is as follows:
1) test the belt for worn or broken
2) power rollers bearing defective test and repair
3) motor need repair.
4) test the thermal fuse
5) test the main switch for open or defectie.
se the diagram
Shark Helmet... | Answered on May 09, 2014
You don't. Call cust. service, they sound send a new head.
Shark Helmet... | Answered on Mar 06, 2014
You cannot. Call cust service.
Shark Helmet... | Answered on Mar 03, 2014
Your motor getting hot. Replace your filters.
There not one. Call cust. service. There help you.
Shark Helmet NV22L Shark Navigator Upright Bagless Vacuum Logo
61 questions posted
Top Shark Helmet Vacuums Experts
Marvin
Marvin
Are you a Shark Helmet Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • Shark Helmet Vacuums
Most Popular Question
out front plastic part empty dirt bag
  • Vacuums
