20 Most Recent Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Questions & Answers
I had the same noise coming out of the side of the canister although I would specify it as a sucking noise. The noise is coming out of a hole on the side of the canister. If you block the hole it sounds normal. This lead me to believe that there was no damage. After further research I found that this whole is actually a release when air cannot make it through the top of the canister. Simple resolution. Take the canister out of its holster and clean both the top part and the metal cone inside and your vacuum will work good as new :) ~=MaGiC=~
Euro-Pro NV22... | Answered on Sep 21, 2020
Hello, this is Ava with Think Crucial
Your Shark model has a thermostat reset feature. If motor should overheat, the thermostat shuts off the power. The link below is the User's Manual for your Shark Vacuum which includes resetting your unit.
Shark NV22 Owner Manual Maintenance
You can purchase a wide variety of high quality Shark replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Euro-Pro NV22... | Answered on Feb 19, 2018
this link is for the manual go to page 9 troubleshooting for help
http://www.sharkclean.com/manual/NV22L-LA-LE-LCO_IB_100603_REV.pdf
Euro-Pro NV22... | Answered on Feb 06, 2018
-Try its web site. It might have one for free down load,.
Good luck
Mai
Euro-Pro NV22... | Answered on Jan 11, 2018
-Broken belt or some thing stuck inside. Check it out and remove or replace.
Good luck
mai
Plugged in:
Try moving the cord around at the strain relief, where cord enters the vac, as internal wires may have broken.
Unplugged:
Check brushes of electric motor, they may be worn down.
Unplugged:
Check main switch continuity with a meter on ohms or buzzer.
Limits:
No.
But there could be a thermal fuse either in or on the motor, to avoid overheating damage and smoke signals!
Euro-Pro NV22... | Answered on Nov 20, 2017
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance of your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they lose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Euro-Pro NV22... | Answered on Oct 25, 2017
You may find the User's Manual for your Shark model by clicking the link below.
Shark NAVIGATOR LIFT AWAY PRO NV355 Owner Manual
Ava B.
Go the back to company there replace the head free
Euro-Pro NV22... | Answered on Mar 12, 2017
If shut off may be motor heated when it cools it should start buy its self
It could be a bad switch or brush roll motor, a broken belt, loose wire or contact. You must inspect and test all these areas to narrow down the cause.
Euro-Pro NV22... | Answered on Mar 03, 2017
Shark has no customer service dept. They do not make parts, and the machines are non repairable. If you just bought it, take it back and get your money back before it's too late. Quality vacs can be purchased for the same amount of money. Miele, Sebo, Riccar are all better and in the same price range.
Euro-Pro NV22... | Answered on Dec 10, 2014
Shark does not make replacement parts. Throw it away, it's a true disposable machine. If you want a second opinion, call any vacuum repair shop, they'll tell you the same thing.
Euro-Pro NV22... | Answered on Nov 28, 2014
Shark has no service dept or customer service. They do not make repair parts. Sharks are true disposable machines.
Euro-Pro NV22... | Answered on Nov 26, 2014
throw it away. It cannot be fixed. Shark does not make repair parts.
Sharks are not made to be repaired. They are built to throw away. No parts are made for them for this reason. Save yourself some grief and don't buy another one.
We have only had our Navigator for 6 months and the bar won't turn. We took the whole beater bar head apart and it was a wiring problem in the beater bar motor.
What a piece of junk this is, very poorly made and has many design flaws.
Looking for something now to take it's place!
Euro-Pro NV22... | Answered on Sep 15, 2014
in addition to the obvious screws, and two under the main coaster wheels, there are 2 hidden under the 2 mini wheels up front. pop them out and remove.
this voids any warenty i think
Euro-Pro NV22... | Answered on Aug 15, 2014
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
145 questions posted
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Muntejaya Ginting
Muntejaya Ginting
Richard Schabler
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Euro-Pro Vacuums
  • Euro-Pro Vacuums
Most Popular Question
switch off
  • Vacuums
