Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range Logo
j
john nelson Posted on Nov 02, 2015
Replaced Self cleaning latching mechanism as original was cycling improperly. Replaced latch and now mechanism cycles continuously. Is there a reset code?
1 Related Answer
Anonymous
  • 135 Answers
  • Posted on May 13, 2008
SOURCE: Dacor ERD36SCH/H will not self clean
Door lock motor suonds like it is bad. Not an easy part to replace. You may need a technician.
Unlock GE JB550GJ - Manual Self-Clean Latch
Self cleaning programs break things 80% of the time. You should never ever use that cycle. 650'F is too brutal to elements, fans, latches and circuit boards that are above the oven. I have never known one with a manual latch.
You need a new stove or a GE Technician service call.
Even parts seem hard to come by if that model number is correct.
https://www.google.com/search?q=ge+jb550gj+parts+schematic&rlz=1C1QJDB_enCA643CA644&sxsrf=AOaemvLbXx0eQ-CuQGcz6uUgtsCr-28esg:1630469374085&tbm=isch&source=iu&ictx=1&fir=-Ou_AjR7rSbftM%252C0lADJSiz3YMlRM%252C_&vet=1&usg=AI4_-kQCddHYo4RSLP9URAtYY3KRG-VIyw&sa=X&ved=2ahUKEwiUt-_e89zyAhWRTd8KHclHDwQQ9QF6BAgREAE
My GE stove is 46 years old :>) The only part that doesn't work is the clock
Sep 01, 2021 • GE Ovens
4answers
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 • Ovens
F5e1 error code
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cooktop. This rod connects to the actual latch mounted behind the oven door. The control board will then monitor a position switch that is actuated by the latch motor cam. As the motor rotates, the latch will engage the door locking it in place just as the cam contacts the switch button. When the switch contacts close, the control turns the latch motor off and starts the cleaning cycle.
When diagnosing this failure, the error code gives us a good starting point to begin our trouble shooting. I removed the rear panel and started a clean cycle. Once the start button was pressed, the latch motor began to rotate, but didn't stop at the locked position. It continued to rotate three times and then displayed the error. I unplugged the range from the wall and using my meter, did a continuity check of the latch position switch (the one on the right). The switch was reading as an open circuit in standby and when I actuated the switch which tells me the switch has failed. The second switch on the latch assembly, by the way, is to turn the oven light off during the self cleaning cycle to protect the bulb. That way, if you leave the light switch on the control panel turned to the on position, that second switch will turn it back off. Good to know if you can't figure out why the oven light won't turn on.
With the failure down to the latch assembly, I checked the range parts to see if the switch came as a separate piece, but it looks like it's an entire assembly, and not individual parts. I removed the old latch after removing the two screws and six wires, then installed the new latchshow?id=y6f3ez5blva&bids=92089.709229668&type=10&subid=. Once all the wires were back connected to the proper terminals, I put the rear panel back on and plugged the range back into the outlet. Started a self clean cycle, but this time I heard the motor make one revolution and stop. The cycle started for the customer and a few hours later, I am sure the oven was nice and clean.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 14, 2011 • Ovens
3answers
Oven door on gas range won't open. Apparently the "clean" cycle was initiated and locked the door and now won't open. Also didn't clean. The range is 4 burner about 25yrs old. I do...
Hello & Welcome to FixYa
This is a common problem that occurs when self-clean cycle is used after a long time or when the oven gets old. Recommended repair is replacing the door latch-lock assembly as the latch mechanism cannot be repaired. Please get back to me if you have any other questions.
Kevin
Upper oven turn on and off then puts f9
F9 indicates a problem with the door latch circuit. Holding the door in the open position, push in the door switch until the cavity light goes off. Put the upper oven in the clean cycle and watch to see if the door latch cycles.
If the door latch mechanism is working correctly, the latch should stop in the closed position (the door will not shut all the way now). If the door latch does not even move and the F9 error appears, which is highly likely, you definitely have a problem with the latch circuit. (If the door latch did cycle to the closed position, cancel the self-clean mode to cycle the latch back to the open position.)
First, check that there are no loose wires on the door latch switches. Also check that none of the wires are pinched between the latch mechanism and the Oven Control Unit. Repair any wires that may be damaged and reconnect any connections that maybe loose. If you have just made any repairs, try putting the oven into bake mode with the door closed and test.
If there was no wiring that needed repaired and all connections looked good, test each of the door switches to be operating properly. Disconnect the wires from one switch at a time and perform a continuity test on the switch. In the open position your meter should read "OL", in the closed position it should emit a tone, or read "0.0". If either switch fails this test, replace the switch and test your oven again.
If none of the above conditions exist, the Oven Control is not reading input from the door latch sensor and needs to be replaced.
Apr 15, 2011 • Ovens
Oven won't restart after self cleaning. What to
Try resetting by turning off breaker for a couple minutes then turn back on. If this does not do it you will need to acess you door latch switch. This is acess by removing the top panel. Check for continuity with latch open you should have none and you should have continuity with latch closed. You can enter your model # at www.appliancehelponline.com to bring up illustrations and parts.
1helpful
Self cleaning oven doesn't work and makes loud noise when you close latch
Hi.
The door latch mechanism must be replaced after reading impedance and volts from EOC to latch.
This kind of problems can be caused by the high temperatures generated on self cleaning cycle.
Regards.
1helpful
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Lock on oven is locked and door open
look towards the center of the door, next to the "self clean latch" youll see a thin metl "plunger", try pressing this in and then restarting a clean cycle, then quicklly cancel clean it should reset the lock/latch mechanism
7helpful
3answers
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Top Dacor Kitchen Ranges Experts
Paul Carew
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
