20 Most Recent Dacor Preference RSD30 Gas Kitchen Range Questions & Answers
Hi!!! You have a problem with your door lock mechanism.it wont lock because its bad..Replace it and you should be fine.Good luck..
Dacor Preference... • Answered on Nov 27, 2018
always shut power off two screws attach element frame to body look at new part for screw holes you may have to remove convection cover in order too see
Dacor Preference... • Answered on Dec 04, 2017
most common issue is burners not placed on proper may have spider web in tube possibly bad regulator if 2 large burners lazy,2 small ok ?
membrane would not cause 9 this is issue with eoc need proper mod #
Dacor Preference... • Answered on Nov 15, 2017
Could be as simple as dirty burners. Take them off and you should be able to clean them out. Do that before calling a repair man. Otherwise you may have other problems. Make sure the burners are all put in the place they are suppose to be.
Dacor Preference... • Answered on Jan 21, 2016
The door closure latch can cause such an issue, if is isn't engaging correctly. Otherwise your RSD30 may need to be reset. Follow the instructions in the owners manual to reset. If you don't have a copy, the link attached below is free to use. Dacor rsd30 User Manual
Dacor Preference... • Answered on Mar 12, 2015
I assume you are talking about a surface burner spark igniter. If so, there may be a failed valve switch. You would need to access the back side of the surface burner valves and disconnect wiring to verify the cause. Selective disconnection at each switch should identify which switch is failed. Look at a parts picture for your exact model range to see the valve switches and identify the part to purchase.
Dacor Preference... • Answered on Jan 08, 2015
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Dacor Preference... • Answered on Mar 08, 2014
Cause for problem could be failed element or failed wiring to element or failed control. Some electrical checks will determine which. If you are not knowledgeable in doing these checks get a repair technician.
Dacor Preference... • Answered on Jan 02, 2014
most ovens will not operate until you set the clock - doesnt matter what you set it to as long as it isnt 00:00
Dacor Preference... • Answered on Nov 30, 2013
Dacor Preference RSD30 Gas Kitchen Range Logo
127 questions posted
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Lee Hodgson
Lee Hodgson
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Dacor Kitchen Ranges
Most Popular Question
spark gas igniter won amp 39 t turn off
  • Kitchen Ranges
