Question about Dacor Preference RSD30 Gas Kitchen Range
Dacor oven will no heat.
Oven door was left open while cooking and now it will not heat. I know there is a reset button for this type of a problem, can you tell me how to access it on model # RSD30 Dual fuel slide in range? Thanks.
Posted by Benny Raja on
  • 2 more comments
  • ewang Dec 18, 2007
    I have a RSD 30 gas range. The oven does not work at all. The door latch is broken. It can not lock the oven door.The push bottoms does not work and the LED only shows one "0" . I can not find any reset bottom like you mentioned behind the latch. The top four burners works fine.
    Inside the oven at the top right has a long rectangle metal box. Is that the thermostat for the oven? Is the reset bottom inside?
    Thank you!
    Eric
  • jgansemer Jun 24, 2008
    Our Dacor oven heats fine for the first use but then if it cools down partially will not reheat (the elment turns on and off repeatedly). The display will say the oven is at 350 degrees but it is more like 205 degrees. If it is allowed to cool overnight it works fine again for the first use of the day. Called Dacor repeatedly; the repair guy can't figure it out who came to the house. Help!
  • rtstark2005 Dec 13, 2008
    Our Oven doesn't heat. The clock works fine, the key pad works fine when setting the oven to broil or setting a temperature for bake. It just does not heat. Is there a reset button, is the fuse out, or is it much more?
    Thank you.
  • sbg114 Dec 15, 2008
    Urgent - Did someone responded to this issue?
    Im in NC and in desperate need to fix this problem.
    It is the holiday...not a good time not to have an oven.
Anonymous
  • 100 Answers
The reset button is located near (probably behind) the latch that locks your door during sef clean. The reset is located in the middle a thermostat that looks like a round disc the size of a quater and about 1/4 to a 1/2 inch high with two wires, one on each side, plugged into it. Usually with a long thin screwdriver and the power turned off you can reset it with out having to take anything, or at least very little parts, off.
Posted on Nov 03, 2007
Anonymous
This solution worked for me. My gas oven would not work even though my burners would. There were 6 screws to undo and I removed the screen that led to the thermostat. Note: the reset button is located on the top of the thermostat and is red (actually is a square red button) - it is behind another round metal disk (that you first will see after removing the metal screen) with wires plugged into to but if you look from the front side view you will see it behind the disk. I reached back with my finger and pressed it down to reset. Thanks all for this great tip - saved me a service call!
Posted on Dec 24, 2007
Anonymous
We have older ( maybe mid 90's) stackable ovens. We tried to use the cleaning feature on the bottom oven and popped the reset switch. To repair, I took the bottom 'kick plate' off the upper oven which exposes the top of the bottom oven. On the very back of the bottom oven (you can reach it with your arm) there is a module that houses a little red reset switch that was popped 'OU'T'. I pushed the button back 'IN' and voila, we have two ovens again ! Took 5 minutes and did not need to shutoff power to the stoves.
Just in time for the 09' Turkey Day !
Posted on Nov 15, 2009
Anonymous
I had this problem where the display panel said "off" and none of the buttons worked. My kids made pizza last night and I know that somehow they left the oven door open and it tripped a sensor.
My solution: I turned to entire stove off at the circuit breaker for about 30 seconds and then turned the breaker back on. It reset the computer chip and the display came back on showing the clock. The oven now works. I have found with any computer related item, if all else fails, turn the thing off, wait a bit, then turn it back on. It resets itself.
Hope this helps somebody else. It saved me a service call.
Posted on Mar 15, 2009
Michael Cook
    New Friend:
Millennia Classic MCS130S
Power off. Take the plate off covering latch. Six screws come out. A cover for the electronics is next, in my case, has no screws. Ease the square U shape sheet out. I eased the right side out, lifting the control panel then twisted the right side into the oven and the left side slide out. About 8-10" in is a right facing red reset. My finger did not work so I used a long slot head screwdriver to press it in. Power on and it worked. I called Dacor prior and they said, "Call a serviceman." Remember that when you buy a new stove.
Posted on Feb 01, 2012
Anonymous
I had the same thing as kbega. Display panel said "off" and oven would not work. Turned off power at circuit breaker, then turned it back on. Worked for a week and then happened again. Did it again today. Will see. Anybody have a more permanent solution?
Posted on Jun 14, 2009
Anonymous
My oven is off and the digital control panel has the word "off" lit up...no buttons can be pushed etc. Doesn't turn on etc. Can you help?
Posted on Jun 15, 2008
1 Related Answer
Anonymous
  • 126 Answers
SOURCE: Dacor oven will no heat.
dacorservice.com very likely has your answers. Good Luck and Happy New Year!
Posted on Dec 31, 2008
Turntable will not rotate and food will not heat up.
If it is not cooking and the turntable will not turn, this sounds like the secondary interlock switch is bad. Almost always this failure is caused by opening the door when it is in a cook cycle. Pushing the stop button before you open the door will prevent this in the future..
Nov 04, 2013 | Dacor DCM24 Convection/Microwave Oven
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Feb 19, 2009 | Ovens
Dec 27, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Wall Oven won't heat - Cannot find thermal reset switch
Open the oven door and unscrew the vented panel at the top. Make sure the oven is off. Atop the electronics in there you'll see a little red button. Push it. Voila.
Dec 24, 2008 | Dacor MCS130 Millennia Electric Single...
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
Dacor Preference RSD30 Gas Kitchen Range Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Marvin
Marvin
Paul Carew
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
