Samsung CLX-3305FW Color Laser Multifunction Printer Logo
J
Judith Dore Posted on Sep 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clean waste toner tank
I get the message replace waste toner tank
J.D. Browning
Level 3:
  • Samsung Master 2,760 Answers
  • Posted on Sep 17, 2015
J.D. Browning
Samsung Master
Level 3:
Answers
2760
Questions
0
Helped
1015223
Points
6696
1st don't wear a new shirt when doing this !!!!
waste toner tanks are not meant to be reused (not saying you couldn't ) but its gonna make a mess doing it so id choose not to do iinside the office that's for sure , replacement tanks are available from same sources you buy toner cartridges from then just tape up the spout and toss old one away , some machines will require a manual reset of toner tank alarm , consult your manual to see how you do it
and if your dead set on cleaning it , what id do is buy one new one install it and take old one outside in a field miles from nowhere using 91% isopropanol alcohol and a hand full of old rags (disposable gloves too) id wipe it clean ,then store it under machine in paper storage box (not tray) so its there ready to use next time you need it
4helpful
I keep cleaning the toner/printer waste tank cartridge and the printer continues to stop printing and the same error message displays saying "Replace/Install waste toner printer cartridge.
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
1helpful
2answers
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
"Replace/Install Waste Toner Tank" error message
Take aout waste toner tank (vertical handle left of cyan toner cartridge)
remove waste toner. Make shure that transparent windows are clean (light barrier). Replace aund resart printer
5helpful
CLX 3160 waste toner tank error message
Empting the waste toner tank does not always fix this problem. Samsung shines a light through the tank with a photo receptor on the other side. If it the photo receptor does not see enough light, it will trigger the replace waste tank message.
You can fix this by trying to clean the clear window portion of the tank with a q-tip. This is difficult to do since there are parts of this window which is hard to clean with a q-tip.
Or you could wash it out with soapy water until the window is clear of toner. Allow the tank to dry and reinstall.
3helpful
2answers
Waste tonner tank
The waste toner container is inside the front cover at the bottom right. If you work for a business you should purchase a new one. If not you may be able to empty it into a another container and seal it before putting into the bin.
5helpful
MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
3helpful
3answers
Replace waste toner tank message
the sensor for the waste toner cartridge is faulty or the waste toner cartridge is faulty it's self.
1helpful
Brother printer mfc-9420cn says to change waste toner. how do i do i this?
when you open the front cover, there is a waste toner tank on the bottom right side of the printer.
Remove the tank and chuck out the waste toner, wipe the tank clean with a cloth and slide tank back in position and close the cover.
this wil resolve the message on the screen
1helpful
2answers
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
1helpful
6answers
Error Message--Waste Toner Tank Full/Not Install
What I have started to do is to actually wash the toner tank out with water and make sure it is good and dry then be sure the section that breaks the light sensor is good and clean (it is on the left side as you look at the backside - the side that goes toward the printer - and protrudes out) the tank full indication comes on when the tank gets dirty
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
