Sony Master
- Posted on Jul 02, 2015
Re: The machine turns on, even the vent, but no image...
Re: The machine starts, even the vent, but no image...
Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
Press the "Menu" key to exit the menu system.
Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
How to Reset Sony Projector eHow
Turn on your Sony projector after replacing the lamp.
Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
