20 Most Recent Sony VPL-HS51A / VPL-HS60 Multimedia Projector Questions & Answers
9answers
Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
12/29/2017 12:01:41 PM • Sony VPL-HS51A /... • Answered on Dec 29, 2017
Service Manual HS51A
Here is the manual... https://docs.sony.com/release/VPL-HS51A_HS60.pdf
3/23/2017 11:15:27 PM • Sony VPL-HS51A /... • Answered on Mar 23, 2017
Hdmi not working on vpl-hs60
HDMI PROCESSOR
4/19/2013 12:21:26 AM • Sony VPL-HS51A /... • Answered on Apr 19, 2013
I connect new LG Blu -Ray On my Sony Cineza Projector.but only blue colour on the screen ,what is the problem here?
You might have to change the input or start playing blu-ray disc and then change input via the remote to your projector. Make sure it's HDMI out on blu-ray if choice is given and HDMI in on projector.
7/10/2012 1:45:22 AM • Sony VPL-HS51A /... • Answered on Jul 10, 2012
I have a big yellow
no you cannot remove, you have to change the screen inside the monitor. the spot cause burn on the screen picture.
8/29/2011 3:02:23 PM • Sony VPL-HS51A /... • Answered on Aug 29, 2011
Ps3 frequency out of range...
This model will only support 1080i. What you need to do is go into the display settings on your PS3 and set the max resolution that your TV will support to "1080i" That should get you going!
4/9/2011 12:46:00 AM • Sony VPL-HS51A /... • Answered on Apr 09, 2011
Sony VPL-HS50, any viewing (TV, DVD) a spread of
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
11/27/2010 1:56:11 PM • Sony VPL-HS51A /... • Answered on Nov 27, 2010
I have changed the bulb
Is the buld u changed right and in working condition.please clean the optic lens and image CRT board which ( Scanner image board) to see if the issue remaisn or nott
9/28/2010 9:33:37 PM • Sony VPL-HS51A /... • Answered on Sep 28, 2010
Reset option killed the yellow warning to replace
The projector's lamp cover might not be securly on or you might need a new one, or the projector has blown a fuse that can be replaced other wise it could be your projector but be sure to contact your sony dealer first.
2/13/2010 10:18:40 AM • Sony VPL-HS51A /... • Answered on Feb 13, 2010
Blue Haze on screen Sony cineza vpl-hs50 projector
Its your blue polarizer going bad. This happens over time due to the excessive heat generated in the projector. The main problem is that your projector has organic LCD panels that degrade over time and in turn degrades your blue polarizer. The same thing happened to my sanyo Z2. It took 5 years for it to show on my Sanyo because I only use the projector for sports and movies. not daily tv watching. In any case, it isnt worth it to spend the money ti fix it...jut put tat towrds a new projector. The latest crop of LCD projectors almost all use in-organic LCD panels that last much longer. Hope this helps.
10/28/2009 8:59:47 PM • Sony VPL-HS51A /... • Answered on Oct 28, 2009
The fleshtones of people on
This is not really a solution but when mine does this I switch the input to the projector to another video source and then back again. this usually makes it go away. If you find a better solution I would appreciate hearing it. Thanks.
7/11/2009 2:30:44 PM • Sony VPL-HS51A /... • Answered on Jul 11, 2009
Not producing any image
There are 2 problems in this post, let me know what problem is yours?
In case of first problem, please check fans are running?
and for second problem, as you said you see Menu of projector then its not bulb (lamp) problem and no picture reason could be bad HDMI cable or HDMI port of projector. Please provide analog video signal either DVD player or computer to make sure that projector has picture from other inputs.
Hit "add a comment" button for further query / info.
Thanks.
4/20/2009 2:57:59 PM • Sony VPL-HS51A /... • Answered on Apr 20, 2009
check the Lamp unit. If Lamp is ok then check the ballast unit
4/19/2009 10:23:54 PM • Sony VPL-HS51A /... • Answered on Apr 19, 2009
I just replaced the lamp
this is our chat session, please rate it inappropriate it will spoil my rating.
vsurg: thanks
cmptrlink: welcome
vsurg: I purchased the bulb through electrified.com. OEM replacement for $249. Is there a difference between bulbs?
Read more cmptrlink: yeah the lamp should be purchased after proper specifing the device model, or the recommended lamp specified by the vendor
vsurg: It is the right lamp. Of that I am sure. The projector is a Sony VPL-HS51.
cmptrlink: hang on i will tell you the correct lamp number
vsurg: Manual says LMP-H130.
cmptrlink: is that the same one you got?
vsurg: Yes
cmptrlink: why dont you consult to a authorized sony service center.
cmptrlink: the lamp no. LMP-H130. is correct. but there must be some problem with the lamp or projector! is the lamp was packed when you got it?
cmptrlink: the projector normaly comes with 3 year warrenty
cmptrlink: To reset the lamp timer: 1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this
cmptrlink: is not clear in manual). 2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER. 3) Timer should now read '0'.
cmptrlink: hello
vsurg: I got disconnected
vsurg: how do i get back on?
cmptrlink: hello sir
cmptrlink: are you there?
vsurg: Iam back
vsurg: How do I get back to the live session?
vsurg: I think I figured it out. I am back
vsurg: Please respond. I can't keep this up much longer
vsurg: How do I get back to a live session please?
3/25/2009 12:16:18 AM • Sony VPL-HS51A /... • Answered on Mar 25, 2009
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
2/17/2009 7:08:25 PM • Sony VPL-HS51A /... • Answered on Feb 17, 2009
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
RESET, <==, ==>, ENTER.
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
2/11/2009 9:01:42 PM • Sony VPL-HS51A /... • Answered on Feb 11, 2009
4answers
Sony vpl-hs51a. wierd picture
Check if the screen or the lines change when you move the cable that connects to the computer. It could just be a bad cable or the connection could be loose.
If you haven't tried yet, do a hard reset. Disconnect the power cable and press the power button on the projector for 10 seconds.
Aren't you getting the same lines on the computer's monitor or if you're using a laptop, the LCD screen?
1/3/2009 11:36:42 AM • Sony VPL-HS51A /... • Answered on Jan 03, 2009
Sony VPL-HS51A / VPL-HS60 Multimedia Projector Logo
37 questions posted
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
AAA TV Service
AAA TV Service
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
big yellow
  • Office Equipment & Supplies
