20 Most Recent IBM Wheelwriter 6 Typewriter Questions & Answers
Only upper half of letters showing
make sure the platen (the rubber roller) is snapped down on both sides
2/2/2017 6:25:57 PM • IBM Wheelwriter... • Answered on Feb 02, 2017
I have am IBM wheelwriter 6. When it powers on the two center line indicators stay on. All functions and keys work as they should. Fresh batteries.
try turning it on remove the batteries check the contacts for clean replace the batteries in the correct direction.
9/21/2016 11:07:21 PM • IBM Wheelwriter... • Answered on Sep 21, 2016
Key striker quit working
Is it still receiving power to do the striking? Check that out!
8/4/2016 8:56:54 PM • IBM Wheelwriter... • Answered on Aug 04, 2016
Replacing the print solenoid cap
The best way to find what you are looking for is to look at your printwheel. Right in the middle of the carriage there is a part that hits the printwheel. That is called the hammer. If you look down on the left side you will see a blue piece of rubber that attaches to the hammer. If you continue to look further down the hammer you will see the solenoid that activates and hits a screw that sticks out from the hammer. The end of the solenoid is where the "cap" can be attached. You do not have to remove the solenoid to install the repair "cap" if that is what you are really looking for. A technician can put in a new cap in less that 30 seconds.
5/24/2016 4:32:09 PM • IBM Wheelwriter... • Answered on May 24, 2016
What does the print solenoid look like
5/24/2016 4:31:25 PM • IBM Wheelwriter... • Answered on May 24, 2016
What is the part number for a ww6 ribbon lift plate?
Here are the part numbers as requested as well as some others. The ribbon plate is 1384819. The ribbon plate assembly is 1384817. The ribbon plate motor is 1384821. You may want to order the whole assembly to make sure as the plate doesn't have the motor on it.
5/24/2016 4:05:06 PM • IBM Wheelwriter... • Answered on May 24, 2016
Wheelwriter 6, flashing #3 beeps 3 times. press any keys twice and it will type.
You batteries need to be replaced, and or the battery holder is corroded. Should be removed and cleaned so acid does not leak inside the machine. Batteries hold the margins and tabs when turned off, not real necessarry.
2/2/2016 10:35:15 PM • IBM Wheelwriter... • Answered on Feb 02, 2016
What causes the problem when the letter l is typed and it will not space on an IBM Wheelwrite 6
You language button is activated, depress code and hold it down then press the lang button. Usually is the L button.
2/2/2016 9:42:36 PM • IBM Wheelwriter... • Answered on Feb 02, 2016
Do you know of anyone who repair typewriters in Sebring, FL or near by?
I googled and found one in port charolette. Ther aren't many of us left if you send it to Cleveland Ohio I'm sure we can fix it or give me a call. Dick O'Reilly 216 269 3918
6/29/2015 11:01:13 PM • IBM Wheelwriter... • Answered on Jun 29, 2015
Line lights are blinking
Which lights? Any beeps? DickyO
6/29/2015 10:48:11 PM • IBM Wheelwriter... • Answered on Jun 29, 2015
IBM Wheelwriter 6 series II, turns on all lights come on solid. will not function
If it makes a growling noise or you cac hear a motor running the carrier belt may be broken or the plastic drive gear cracked. Nothing at all most likley a board. DickyO
6/29/2015 10:40:50 PM • IBM Wheelwriter... • Answered on Jun 29, 2015
2answers
Carriage will not return on 2 of our IBM Wheelwriter 6, can this be fixed?
First spray some WD40 on the silxer shaft that the carrier slides on they get really gummy, if this works run it back and forth a few times then clean the shaft off with a rag. DickyO
6/26/2015 9:34:43 PM • IBM Wheelwriter... • Answered on Jun 26, 2015
When I type a lower case t, it types out as two consecutive up and down lines
This is a symptom of a bad print wheel. One or more of the spokes on the printwheel are bent or broken. Replacing printwheel is about the only option. Printwheels run about $60.00.
3/16/2015 9:32:58 PM • IBM Wheelwriter... • Answered on Mar 16, 2015
Ribbon will work in one Wheelwriter 6, no print output in another one
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
3/2/2015 10:41:36 PM • IBM Wheelwriter... • Answered on Mar 02, 2015
Keys strike paper but don't space
Is it all of the keys or just some of the keys don't space? Check to see if the lang light is turned on. If it is, hold down the control button (the button left of the spacebar) and hit the letter "X" and see if the light goes out.
3/2/2015 8:26:58 PM • IBM Wheelwriter... • Answered on Mar 02, 2015
My IBM 6783-2 will not print any letters and the hammer is not striking the wheel
3/2/2015 8:22:43 PM • IBM Wheelwriter... • Answered on Mar 02, 2015
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
3/2/2015 8:19:48 PM • IBM Wheelwriter... • Answered on Mar 02, 2015
IBM Wheelwriter 6 Typewriter - while typing, characters just quit printing on paper. Checked ribbon, machine etc. Everything checked out?? What could be the problem.
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
2/24/2015 5:29:14 PM • IBM Wheelwriter... • Answered on Feb 24, 2015
Lang light on how do I fix ?
Hold down the Control button (the button left of the spacebar) and the hit the letter "L". This will turn it off.
2/24/2015 5:17:37 PM • IBM Wheelwriter... • Answered on Feb 24, 2015
Memory erases when turned off
There are AA batteries in the machine and it takes either 2 or 3. You can replace them when the machine is on as that will not harm the machine or you. The batteries should be replaced every one - two years. Replacing them when the machine is turned on will allow the current memory to remain intact.
2/24/2015 5:05:05 PM • IBM Wheelwriter... • Answered on Feb 24, 2015
IBM Wheelwriter 6 Typewriter Logo
132 questions posted
Top IBM Office Equipment & Supplies Experts
Gary
Gary
Fix It Fast...
Fix It Fast...
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Office Equipment & Supplies
Most Popular Question
ibm wheelwriter 6 series ii turns all
  • Office Equipment & Supplies
