Your computer has "queued" various pages to be printed.
When it detects that it cannot completely complete the output, it restarts the sending of the information to the printer.
From the Windows "Control Panel", select "Printers".
Select your printer. Click to "show what is printing".
From there, you can select an item, and choose to "cancel" it.
Runaway print jobs are always a pain! First, power off your printer to stop it from wasting paper. If the power button doesn't work, pull its plug. That will stop the printing for now but your print job will probably restart when the power is resumed.
Whether you are using a PC or Mac, documents that you send to the printer are managed by a printer management service which is responsible for printing documents in the correct order and handling any printer problems that occur. When the printer is turned off, any documents you print will be saved (queued) for printing when the printer starts again. To fix your runaway printing problem you simply need to delete the copy of your large document that is still queued for printing.
On Windows you will see a small icon on the toolbar at the bottom right of your screen that looks like a printer. When you click on the icon you should see a window appear which has the name of your printer in the title bar (e.g. HP Deskjet) and a list of any documents waiting to be printed. To delete a print job, simply right-click on the document name in the list and select "Cancel". When asked "are you sure you want to cancel the document" click on YES and the document will be deleted from your printer queue. Repeat this for all documents in the list until it is empty, then you can restart your printer.
The process on a Mac is similar and even easier since you will see a bouncing printer icon with an exclamation point on it on your toolbar. Click on that icon to see the print queue, click on the document you want to delete and press the DELETE key to remove it.
Click
Start - Printers and Faxes - Double Click on the Canon LBP-2900 printer
- Click on print document you wish to cancel then click on the Document
at the top next to Printer and View then click on Cancel.
Yes, printer won't print if print queue is full. The fact is you are lucky your printer is giving you this message. Most printers, when queue is full, will just remain silent and leave you wandering what in the world has gone wrong. Solution is to clear the print queue. See, when you send to print and you send another when the previous hasn't printed, they queue up. Now if for any reason the first fails to print, all others will just remain queued up but will not print until you clear the print jobs queued up. To do, this go to start/control panel/printers. Right click on printer icon and select open. The respective print queue box appears. It should have all of the print jobs listed there in the box. On the menu bar click on printer and select "Cancel all documents." A box appears asking you to confirm if you want to cancel, answer yes. Then try to print again. If it still fails to print restart your PC and try to print again.
Your problem lies in the vista software. This is a common problem where Vista cannot often read the software drivers quick enough or are not compatible which makes it not work properly. My advice would be to get rid of vista and go back to XP, it was much more compatible with everything. Problem could also be in the cable. Make sure they are plugged in nice and snug. Cheers.
Delete Queued Print Job
If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
On the Windows taskbar, double-click the printer icon located to the left of the time.
At the Printer window, select the print job, under 'Document Name' column, to highlight it.
From the 'Document' menu, select 'Cancel'.
Repeat steps two and three to cancel another print job.
Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
Close the Printer window.
Shut down the computer.
Disconnect the printer cable (USB or parallel cable).
Restart the computer.
If a message window appears asking to cancel printing, select 'Yes'.
Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
Go to Settings or Control Panel and select Printers - double click the icon. Here you will find the Print Queue. Delete all jobs in the Print Queue (the first one is probably the problem child and is stopping any others from progressing).
This will free up the Print Queue which should now be ready to accept new Print jobs.
Note: The Spooler is an area where Print Jobs are stored ready for Printing and as long as the previous print has finished then the next job in the Spooler will progress to be printed onto paper.
Please check the following items: Check item 1: The cable may not be securely connected between a printer and a computer, or be about to be unconnected. Check that the cable is securely inserted into the ports of the printer and the computer respectively. If a USB hub is used, connect the printer and the computer directly.
