The milk heats up but machine does not go into froth mode
SOURCE: Aeroccino part for warming milk
you should contact nespresso to buy a new one.
www.nespresso.com
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
SOURCE: Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
SOURCE: My Aeroccino doesn't froth the
We had the same problem and it could be that you need new whisks. If you phone Nespresso they will send you out new ones (one of each).
Betteboo
SOURCE: the milk doesnt heat up
We had the same problem with burn marks on the bottom and flashing red light etc. Now we just rinse the container out with cold water each time we use it - do not dry, just leave it wet and then add your milk. Heats up perfectly each time. The water lubricates the base of the container, preventing burning. Nice hot coffee every time now. Hope this works for you too!
