20 Most Recent DeLonghi ESAM6600 Espresso Machine Questions & Answers
I would suspect heating element or temp controller.
DeLonghi... | Answered on May 12, 2018
Did you figure out how to remove the faceplate? I am trying to do this to track down a leaking issue.
DeLonghi... | Answered on Feb 22, 2018
On this page there are some options for parts,
http://www.delonghi-accessories.com/index.php?cPath=448_83
There is also a phone number where you can call: 18008656330
DeLonghi... | Answered on May 07, 2017
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
DeLonghi... | Answered on Jun 02, 2014
are the pucks solid or loose in the grounds container ?
Probably the diffuser needs greased - or 25quid gets a new one
DeLonghi... | Answered on Feb 21, 2014
You can order the part from appliancefactoryparts.com
You need to replace the entire control board. The display is built into it, but it is easy to replace.
You just need a screw driver to install the display control panel.
To install the part, do the following:
Turn off the unit and unplug it.
You need to remove the screws on the back of the unit and remove the back. It slides up. Then slide the sides toward the back. You need to remove the side without the water canister. The side with the water canister just needs to be slid back enough to reveal the screws at the top front of the unit holding the display. Remove those screws on both sides and gently pull the top front display cover off. There is a long ribbon (similar to one found on a hard drive in acomputericon1.png, which is exactly what this is) with a clip that attaches to the main control panel on the left side of the unit. Remove that (noting how and where it attaches - I mark everything), take apart the inside of the front panel to reveal the display board, remove and replace it along with the water tight seal. Plug the new display into the control board, reattach the top front panel to the body of the machine, reinstall the water container, plug it in and turn it on to see if it works. Mine did and so I reinstalled the sides - they just slide forward, then I reattached the back and the machine was good to go.
Hope these instructions help.
DeLonghi... | Answered on Feb 15, 2014
tube water clogget.Try to remove nozzle and hot water with a thin needle dig in the hole of the machine where the water comes
DeLonghi... | Answered on Nov 28, 2013
DeLonghi ESAM6600 Espresso Machine Logo
36 questions posted
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
ESAM DeLonghi
  • ESAM DeLonghi
Most Popular Question
display not working but otherwise
  • Coffee Makers & Espresso Machines
