Toshiba e - 356SE when you put paper in the bypass, after withdrawing the paper Job Status is blinking. And the status of the machine, see the paper is sspnd States. You want to take single or multi-copy, paper comes out the same job status is blinking. The paper comes out
SOURCE: how do i get the bypass feeder to start printing
put the paper in the bypass and select paper type.
SOURCE: i'm giving a print of a pdf file but printer not
go into you printers folder look for the toshiba printer right click on that go to properties and change the paper seting on that property menu
SOURCE: I have printed this file many times, sent file to
Try this, Press the Cancel button several times, leave it for few minutes, and then Turn off and switch on while you keep pressing the cancel button. If there's memory installed on the Dimm slot, remove it and re-install it.
Also check the print queue, Start > Printers and Faxes > double-click the printer's icon, click "printer" on the menu and select "Cancel all Documents" click "Ok" and restart both computer and the Machine. (I assume your computer with windows Operating System Installed.)
Sometimes reseating the cartridges and drum is helpful. You can give a try. But since you can make copies, I don't suspect the issue's related to the machine, but with the computer and memory.
Disconnect and reconnect the cable (usb) connecting the machine to the computer.
Good luck.
Thanks for using FixYa.
SOURCE: What does job status code
It's an E-mail related error message. The message is exceeding the file capacity. Reset and extend the message size limitation or reduce the number of pages and try the job again. Hope this helps
SOURCE: My toshiba copier keeps saying job status change
my toshiba e studio 351c keeps telling me to join finisher to copier
