Samsung SCX4623F Laser All-in-One Printer Logo
m
moabi otukile Posted on Oct 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How should i solve my printer it say manual paper empty
Roger Binsfeld
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 133 Answers
  • Posted on Oct 23, 2014
Roger Binsfeld
Expert
Level 2:
Cheetah:
Answers
133
Questions
Helped
39176
Points
202
It sounds to me that your paper size is not correct so it is tring to pick from the bypass. put paper in the bypass until that job is over or delete that print job. make sure your paper cassette is set to the right paper size. most of the time this problem comes up when rinting pdf files or from the internet.
2answers
How to fix the red light and not working on samsung ML-1866?
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see "Clearing
Paper Jams" on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See "Installing the Toner
Cartridge" on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
MY PRINTER SAYS ...MP TRAY PAPER IS EMPTY DURING PRINTING
Put more paper in the Manual Feed tray to allow it to continue or change the settings to bypass Manual Feed Options.
1helpful
T644 Default Paper Source Problem
On the left side, near the pichup roller, of the tray there should be a "flag" hanging down in the elips hole. See if it is hanging down or stuck in the "up"position.
If so pul it down and the machine should work fine again.
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
1helpful
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
6helpful
2answers
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
1helpful
2answers
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
receiving data.
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
