Unit has power. This is the first time this has happened. lock out light blinking steadily. will not run a cycle for more than a few seconds, then turns itself off, back to lock out blinking light. HELP
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When
the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all
buttons are non responsive). It does this as a safety in case the
element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring).
It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
SOURCE: Blinking Clean light in Whirpool dishwasher
Control is programmed to stop
running and not allow any
further cycles if it detects a
water heating problem (no
temperature increase detected
in heated Main Wash on
3 consecutive cycles). Control
blinks the Clean LED 7 times
repeatedly and disables the
Start/Resume key until
cleared.
Running Diagnostics clears the
control and allows it to operate
again. The water heating problem
must be fixed or the control will
stop running again. See potential
causes below.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater circuit.
■ Faulty heater drive circuit on
control.
1. Check operation of heater in
Diagnostics cycle.
2. Unplug dishwasher or disconnect
power.
3. Check resistance of heater and all
components and connections in the
water heating circuit or heat dry
circuit.
dont forget to vote
hope this helps
thank you
SOURCE: WHIRLPOOL ADP 8540 dishwasher has
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
