Dishwashers Logo
Bob Jetter Posted on Nov 05, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clean light blinks on whirlpool dishwasher won't run
Curt Mueller
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 182 Answers
  • Posted on Nov 06, 2021
Curt Mueller
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
182
Questions
8
Helped
288767
Points
374
If your Whirlpool dishwasher does NOT have a digital display, the clean Light will flash the function code then the clean Light will pause for 2 seconds and then will flash the problem code. You need to count the number of times the clean light flashes to find out the error code on your Whirlpool dishwasher. As an example: If the clean light flashes 5 times followed by 2 flashes (5-2) then this error is showing the function code = “Door issue” and the problem code is “The door switch is in question”. The flashing light patterns repeat again after a 5 second pause. NOTE: The control panel console is fully non-functional when an error code is flashing.
my opinion
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 05, 2021
my opinion
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
8
Questions
0
Helped
5710
Points
24
If you aren't sure whether Control Lock is on, press a cycle button on the keypad. If Control Lock is on, the light will blink three times.
Turning off Control Lock:
  1. Press and hold the Lock Button for four seconds. The lock light will disappear.
  2. Once off, you should be able to start your wash cycle.
Note: If Sleep Mode is on, turn that off first, then turn off Control Lock.
Like many other electronics, you may need to reset the dishwasher control panel by turning it off, waiting, then turning it back on.
  1. Press the OFF button.
  2. Disconnect the dishwasher from its power source by unplugging it or by turning the circuit breaker off at the electric panel.
  3. Once disconnected, wait one minute, and turn the power back on.
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 • Dishwashers
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
20helpful
2answers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
WHIRPOOL DISHWASHER CLEAN LIGHT SATYS BLINKING AND IT WON`T START WASH CYCLE
you have either a bad heater and or your water temp is too cold
toggle heated dry and high temp wash withing 8 seconds until all the lights light up
then hit cancel you should be able to use it now
Dishwasher clean light blinking won,t run or let you start. How do you reset?
here is the user manual you can downloads
Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher
and here is the parts list that will help you fix it you need to check the breaker to make sure it has not tripped.
here is the parts list and prices, hope this helps get back to me if you need more help thanks for using fix-ya
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135108&diagram_id=954020#d954020
The clean light is blinking on the dishwasher. i
if its flashing 7 times. make sure hot water 120degree goes in unit. if water is satisfied then replace heater and main board. its a kit
Kitchenaid KUDS01FLBL2 dishwasher will not run
Juan, I found this http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
It should help you out with the issue you are having with your dishwasher. Watch the video too!
Best of luck
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
