When using either feeder if quite often doesn't feed the paper through. It will either give the printer message that it is jammed or it just shoots the paper straight through.
I like to print on moab entrada and use the back feeder and still have the same problem. When I finally do get a print...usually 6 ot 7 tries...the prints are beautiful. Help!
SOURCE: paper sent through without printing
You should try cleaning the pick up roller. It may be your paper has quite a dusty surface and this will cling to the pick up roller making it less grippy. When the paper is fed it may not make the first sensor in the expected time and thus creates the error. Get a service manual to show you how to get a t the pick up roiller so you can remove and clean it. You can get Platen Cleaner from many web sites and it is specifically formulated to regain friction os such rollers. Try either: http://wwwTheServiceManualShop.com or http://mikeburton.tradebit.com/ for a service manual
SOURCE: printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
SOURCE: paper feeder is not straight
I found the problem with the image coming out skewed.
When the toner cartridge is replaced it is easy to dislodge one of the springs on the inside .
There is one on the left and one on the right side.
If one comes loose then the paper will feed through crooked.
SOURCE: automatic document feeder doesn't feed
Possible a piece of paper is in the paper path, you will need to check all the rollers and insure there is no paper remains.
--- Please dont forget to vote if you liked my answer thanks
Check
the following:
Paper
type
Load
up to
this many sheets
Plain paper
Approximately
120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper
Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do
the following:
1. Gently pull any jammed paper out from the output
tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson
Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus
NX400. Open the scanner, remove the jammed paper and torn pieces, close the
scanner, and turn the Epson Stylus NX400 back on.
