I.e. some lines print and others are skipped (some lines print only partial - like the top of the letters). I have tried changing the cartridges and performing the various maintenance functions.
I'm late on this....
The most likely is the cartridge. If cartridges are not OEM, they might have under quality laminate to seal the join between printhead and cartridge.
I have 27 years repairing printers and also have a magister with several Epson printers I use in my printing retail store.
By the way, I HATE THEM, but are better than Brother, or Canon or HP...
It is a tough problem with the printout if you are using non OEM cartridges, but they are too expensive
Re install the printer driver or its paper detecting sensor is faulty
SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate. I know precisely what your problem is, and you aren't going to like what I have to say. What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer. I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue. I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem. The issue you are having is with the Epson print head, which uses piezo technology. What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber. It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet). Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture. Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy. The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head. It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head. Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it. If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not. Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol. However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed. If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours. If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem). The solution is to acquire a new print head. Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer. Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge. Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy. Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
SOURCE: Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
SOURCE: epson sx200
Fixed the problem by running several sheets through the printer,emptying the black cartridge(which was where the problem was),and installing a fresh black cartridge.
SOURCE: I have just changed the
Click Start, go to Control Panel > Printers (Vista) / Devices and Printers (7) / Printers and Faxes (XP)
Right click on your printer, click Printing Preferences, click Maintenance, click Nozzle Check.
If the Nozzle Check pattern isn't complete, do a Head Cleaning and print the Nozzle Check pattern again.
You can do the Head Cleaning cycle 3 times, and make sure to print the Nozzle Check after each Head Cleaning cycle to see if there are any improvements.
You can also reinstall the inks by clicking Ink Cartridge Replacement and following the instructions.
If that does not work, please call your local service center or the store where you purchased the printer for warranty options.
