20 Most Recent Epson Workforce 520 Printer Questions & Answers
I had this issue and contacted epson support. They had me open the top to access the cartridges and physically slide the cartridge from its resting place over to the other side and and there was a small piece of paper that got caught in a print and was between the the ink and the cleaners. I then needed to physically move the cartridges back to the resting place and then close the top. Then on the printer, go to the menu and clean the nossels and the test the cartridge. if the lines are broken at all or you dont see words at the top of the test page, then clean the nozzles again. complete this and print a test page or copy. I was good to go.
Epson Workforce... | Answered on Dec 09, 2020
If you are using the Windows Vista or Windows 7 Operating System, please disable UAC Feature from Control Panel.
You can Re-Download the Driver from the following link:
http://www.epson.com/cgi-bin/Store/support/Supportdlsurvey.jsp?BV_UseBVCookie=yes&download=ftp%3a%2f%2fftp.epson.com%2fdrivers%2fepson13779.exe&pn=WorkForce+520&pc=Epson+WorkForce%26%230153%3b+Series&ft=driver&returnpage=%2fsupport%2fsupDetail.jsp&returnparams=%26infoType%3dDownloads%26oid%3d152503%26prodoid%3d63087903&licenseoid=17774
Enter your Email details go ahead with download process.
Then install the Driver.
Epson Workforce... | Answered on Jul 16, 2019
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Epson Workforce... | Answered on Nov 19, 2018
Hey, here's the whole process, step by step:
Solved How To Reset Epson Ink Cartridges
More info under: Gadget Preview
Epson Workforce... | Answered on Aug 14, 2018
Yes, Turn the router upside down and write down the network name and wireless key.
Epson Workforce... | Answered on Feb 22, 2018
Have you:
1. run a nozzle check?
2. run head cleaning?
3. done head alignment?
Steps 1 and 2 are my first Epson fixup for your described problems.
Epson Workforce... | Answered on May 18, 2016
Are there any error messages, or blinking trouble codes? The last piece of paper will sometimes jam or go in skewed, so perhaps it has a small piece of paper in the rollers.
Epson Workforce... | Answered on Mar 24, 2016
It is obvious that you didn't download the correct driver or if it is new, you didn't remove the packaging properly. Please check all the cable connections.
Epson Workforce... | Answered on Nov 16, 2015
look carefully at where the color cartridges go in and there is a small color band for the correct cartridge position
as each cartridge is colored , just match the colors and it will be right
Epson Workforce... | Answered on Oct 19, 2015
re install your printer driver
Epson Workforce... | Answered on May 09, 2015
Hi, try the following:
Turn the printer off and wait a few seconds, then turn the printer back on.
Push Menu.
Push the arrow down key to get to "Maintenance"
Trust this helps, regards Alan
Epson Workforce... | Answered on Mar 04, 2015
simply check if there is some part of paper stuck inside also you should clean it from dust weekly or when its need when-try-print-jziwo0yngimbtws3xau0igz3-2-0.gif when-try-print-jziwo0yngimbtws3xau0igz3-2-2.gif
Epson Workforce... | Answered on Nov 28, 2014
Look in the left side of the printer, you'll see some wheels
Shut the printer down and pull the power cord
manually rotate the wheels until the little lever that block the carriage moves
When the carriage is unlocked, you are free to move the carriage.
Hope the Best
ADCSFXworks printing center
Epson Workforce 520 Printer Logo
206 questions posted
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
WorkForce Epson
  • WorkForce Epson
Most Popular Question
changed cartridges but now faces green
  • Office Equipment & Supplies
