Samsung SCX 4521F All-In-One Laser Printer Logo
A
Anonymous Posted on Jul 31, 2014
Printing 2 pages on one side samsung - Samsung SCX 4521F All-In-One Laser Printer
HEMANT GROVER
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Samsung Expert 171 Answers
  • Posted on Jun 25, 2016
HEMANT GROVER
Samsung Expert
Level 2:
Cheetah:
Answers
171
Questions
0
Helped
119239
Points
243
In printer preferences , choose multiplespages
My Samsung ML2851ND jams on first page of two sided printing as it is being pulled back into the printer. The left side does not grab the paper as well as the right side. After the first page is cle
Dear
While duplex print some times this jam happen. Try on detach a leaver (black in color similar to comb) attached to back door of the printer.
Thanks.
How can I do a 2 sided print
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
I have a printer thats printing on one side only. how can i fix this
Do you mean double sided printing? If so this model printer does not have a duplex unit and cannot print double sided prints automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will beprinted on the other side of the page 1).
Repeat this procedure for the other pages.
2 sided booklet option
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Can this samsung print two pages on one paper? you know, like two sides?
This is not possible by default but by some manipulation it is All you have to do is print the first page out but remove the paper tray so the device does not pick up the second page immediately after then put back the printed page on top of the paper stackand position it the other way around so the printing will be done on the other side
Hope this solution has been helpful?
1helpful
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Valid page names message driving me nuts
when printing specific pages the valid range is in this format 1,3,5,7,9,11 etc or if printing even numbers 2,4,6,8 etc or if printing specific pages 1,5,17,21,23,24,32 etc
what makes it a valid range is the comma between the numbers, no spacing and no full stop at the end
to further add confusion
when printing all of the pages just click all pages and it will print one sided all of the pages so no numbering is required
however if you want to save paper and reduce the size of the document
click pages 1,3,5,7,9,11,13 through to ,57
print those pages then turn them all around and upside down reinsert in the printer
now select pages 2,4,6,8 through to ,58 and print
that will give you printed data on each side of the paper in the correct page number order
to get to know how to reinsert the paper test with a print page 1 then reinsert and print page 2 to make sure that you have turned the paper the right way round
2answers
SAMSUNG SCX 4100 PRINTING PROBLEM
I am facing the same issue, but its related to Copy (not Print).
The carriage/CCD Light in the scanner is stuck in its original position, causing a scanner error, and all I get are 3/2 vertical lines on the page. Some time I also get an empty page out.
7helpful
3answers
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
