Error code F7 normally indicates a fault with the flow meter. This is located inside the plastic tank, on the left side of the machine.
1. Unplug the appliance.
2. pull it out (if under counter).
3. If it's a freestanding model , remove the top. Then take off the left side panel.
4. Locate the plastic tank, on the side of the tub, is the flow meter.
5. There is a small plug attached to it. Pull the plug off and plug it on again several times. This should clean up connection which may have become corroded.
Put it back together and try the machine again.
