20 Most Recent Whirlpool DU1010XTX Builtin Dishwasher Questions & Answers
contact the installer to get the user manual or call for a warranty service for the unit
Whirlpool... | Answered on Jun 18, 2017
Hi
The issue is with drain hose that is not in correct position, please check that and post back for further assistance.
Daniel
Whirlpool... | Answered on May 23, 2011
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Whirlpool... | Answered on Dec 04, 2010
The soap door is opened by heating a bimetal bar that bends when electricity is applied. This prevents the door from opening when the cycle is momentarily selected preventing the soap from dumping. The unit is behind the soap cup in the door.
Whirlpool... | Answered on Nov 17, 2020
either full water sensor bad or water solenoid stuck open
Whirlpool... | Answered on Nov 01, 2020
The circuit protect in the power supply needs to be replaced or check the wire nut electrical connections to the unit.
Whirlpool... | Answered on Oct 05, 2020
The connector ribbon cable oxidizes connecting the keypad, replace the keypad!
When the dishwasher starts to make funny noises or working loudly, it is usually because there are debris caught in the draining pump, although a problem with the motor is also possible.
Drain Pump: The drain pump might needs to be checked for debris. If its clean and noisy it needs to be replaced.
Circulation Pump: Bearings inside the circulation pump will wear out over time and can cause a loud groaning sound while the dishwasher operates.
Wash Impeller: The wash impeller has small plastic blades that help with water flow to the control arms. If one of the blades breaks there could be a noise. It may also be improperly aligned. Inspect for any signs of damage.
Source: https://www.electrafixbc.ca/appliances/dishwasher.html
Whirlpool... | Answered on Aug 27, 2020
https://www.youtube.com/watch?v=eUD0HMC0OvI
https://www.hunker.com/13407814/what-causes-a-whirlpool-dishwasher-to-have-a-flashing-light
Whirlpool... | Answered on Apr 25, 2020
https://www.youtube.com/watch?v=l8GFXlVGY-8
Whirlpool... | Answered on Apr 14, 2020
All dishwashers are "tall' now. But will fit under counters wiring diagrams are glued to the inside of the panels
Whirlpool... | Answered on Feb 21, 2020
Video at the link below suggests it may have a locking feature:
https://m.youtube.com/watch?v=XAauYps8k5E
Whirlpool... | Answered on Nov 28, 2019
Where is it leaking from? It'd it is under the door, check the door gasket for tears.
Whirlpool... | Answered on Nov 26, 2019
i don't know. as it is new, i would call the seller or the manufaturer to see if this a normal condition or if a free service call is necessary.
Whirlpool... | Answered on Oct 26, 2019
Whirlpool DU1010XTX Builtin Dishwasher Logo
13 questions posted
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
quiet partnr 1 diswasher new installed
  • Dishwashers
