20 Most Recent GE Profile 30" Self-Cleaning Slide-In Electric Range - Black-on-Black Questions & Answers
In order to save your sanity, you'll want to "reset" your oven. Turn off the breaker for the oven circuit for about 20 seconds and then bring it back to the ON position. If you're handy enough to make your own repairs on the oven then you'll want to go to "www.repairclinic.com" to find out what you need to do to troubleshoot your F-7 code.
GE Profile 30"... | Answered on Feb 03, 2019
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
GE Profile 30"... | Answered on Jan 08, 2016
pull the knobs off,there are nuts under the knobs,unscrew them and slide the panel off,underneath you should be able to get to it,remember,you heat food there and unplug it,dont spray bugspray on it,figure out where they are getting in and put boric acid in the way so they will drag it to their den and kill them,boric acid is better known as cockroach powder,but,it works on all bugs
GE Profile 30"... | Answered on Jun 02, 2015
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
GE Profile 30"... | Answered on Mar 20, 2013
What is the model number of your unit?
GE Profile 30"... | Answered on Nov 22, 2012
GE Profile 30" Self-Cleaning Slide-In Electric Range - Black-on-Black Logo
52 questions posted
Top Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
ge profile oven blinking locked oven
  • Kitchen Ranges
