HP LaserJet 4600 Printer Logo
D
Dave Posted on Jul 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do I get 3 groans during calibration accompanied by a 51.2m error ?
Gary
Level 2:
Novelist:
  • HP Expert 301 Answers
  • Posted on Jul 20, 2014
Gary
HP Expert
Level 2:
Novelist:
Answers
301
Questions
Helped
141825
Points
480
51.2 is a laser error.
there should be another number after the 2,
0 = black laser
1 = cyan laser
2 = magenta laser
3 = yellow laser.
The groan is most likely the polygon motor has lost its lubrication and may just need to be cleaned and re-lubricated.
You can also try reseating the connectors from the lasers to the DC controller PCB...
New t880 tractors keep showing a calibration memory fault code. need helping figuring out what that means
On a new unit, the memory spaces for past calibrations are empty. The calibration memory gets filled during early operations and then the error should go away.
2helpful
During tank refilling
With switch on press YES/ENTER & STOP/NO key at the same time and watch the screen to come back as normal condition. If it is the same then you have to replace SCALE assy.
After replacing SCALE assy.you must CALIBRATE the new scal before use the machine. For calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Hope this will solve your problem & if my solution is useful to you please vote for it.
17helpful
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
1helpful
Calibration error - reader won't install on windows vista 32 bit
1. Using the stylus, tap the "X" to restart the calibration process. 2. Tap the center of each "X" that appears on the screen. 3. When "Touch Panel calibration completed" is displayed, click "OK".
After use, while its refilling, my Rheem hot water heater makes a banging sound inside. Anyone have this issue?
I suspect the noise is being caused by expanding metal groaning or 'popping' due to the expansion. We have a metal roof on our home and heating and cooling are always accompanied by similar noises that are inaudible inside the house but catches our attention if we are on the porch.
1helpful
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
Power Calibration Error.
first re install your nero .and
A) Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). And during the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times.
So, when you receive the "Power Calibration Error" or "Power Calibration Area full" error message, then the cause will be either poor media, poor Power, or a defective Recorder.
POSSIBLE SOLUTIONS:
1) A might enable the OPC on this medium
2) Try another brand of CDR or CDRW media.
3) Also try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If this occurs with an External recorder, the power source in the chassis could be the cause. Take the recorder out of the external chassis, and connect it internal, as a test.
4) Try different configurations, such as taking the CDROM to the Primary IDE bus as Slave, and have only the recorder connected to the Secondary IDE bus as Master.
5) Send the recorder in for Service.
Here is the direct Link: http://www.nero.com/en/632181809668074.html#23
I Hope this helps,
k24674
Grand Canyon Tech
Grand Canyon Tech
