Paper will not feed into printer
SOURCE: Canon Pixma MP160 paper will not feed
try the feed button which is usually on the front of the machine. press once
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
SOURCE: how to install a canon pixma mp495 printer with no
CANON puts its device-drivers onto its web-site: http://www.canon.com
Click "Support" or "Downloads".
Enter your model-number.
Select your Operating System.
Download the device-driver.
Install it.
Print.
Testimonial: "You guys are awesome thanks"
SOURCE: Where can i find the serial mumber on my canon
PIXMA Printers and All-In-Ones
The serial number is located inside your PIXMA printer. To find it, open the printer lid as if you were to access the cartridges tray: the serial number is printed on a white sticker. Be careful to not confuse this number with the power supply serial number that can be found on the bottom of your printer.
Hope it helps.
