I have a Vzon flat screen and the volume does not work. It is locked in four so if I were to lower the volume the number goes down but the tv mutes, My tv has to stay on or above 4 on the volume or it wont display a sound, how can i fix this?
SOURCE: Magnavox 30MF200V/17 No picture, only sound
Do you know if i can use an inverter from any LCD tv, or does it have to be specific to that model? I was thinking about taking an inverter from another broken TV.
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
SOURCE: Vibrating sound from TV unless volume is way low.
Ive got the same bloody problem, Sooooo Annoying!!!!!
SOURCE: The volume on the TV doesn't work. TV worked fine last night
You can always turn your TV off, unplug it from the electrical outlet, wait for 30 seconds or so, plug it back in, then turn it back on. If you have kids check the menu options to see if they may have tampered with it unintentionally. If all else fails, call Vizio and ask for their professional help. If you are not satisfied with their help and assistance, make a complaint by going to BBB.org (Better Business Bureau). Maybe if you tell Vizio that you're going to call the BBB then they might take you a little more seriously.
SOURCE: No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
