20 Most Recent Coby TFTV3225 32 in. LCD TV Questions & Answers
Is there a service menu code for Coby TFTV3225?
Geez people....
Y'all are giving codes for remotes and trying to tell how to replace parts... all they asked for was the service code.... to access the service menu.
The answer to their question is to take the factory remote and press MENU button... then just highlight the AUDIO icon... then press 8893... and THAT will automatically open up the Coby TV's factory service menu.
You're welcome.
11/9/2018 5:42:48 PM • Coby TFTV3225 32... • Answered on Nov 09, 2018
2answers
My tv will not turn
The standby power supply is working but not the rest, it can be due to bad caps in the power supply, or it is detecting shorted circuits do it stay in shutdown mode. You need to do in-depth troubleshooting, please read my guide first.
Basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/ Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: www.interliquidparts.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
10/2/2018 11:54:57 AM • Coby TFTV3225 32... • Answered on Oct 02, 2018
2answers
Reset button on coby tv
I have a 42 inch. Under the Coby name on the lower center front are two buttons that light up. The reset is the smaller of the two buttons. Good luck, it seems I have to use mine too much Thanks
6/22/2018 3:57:21 AM • Coby TFTV3225 32... • Answered on Jun 22, 2018
My 19" LED Coby tv
[email protected]
I looked but no known phone number
2/6/2018 5:02:49 AM • Coby TFTV3225 32... • Answered on Feb 06, 2018
0answers
What sound bar will work with coby 32 tftv3225
Any soundbar should.
2/1/2017 5:41:08 PM • Coby TFTV3225 32... • Answered on Feb 01, 2017
It has a horizontal lines at the bottom of screen,then after a few minutes lines radiated all over the picture and color fades
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the keyword "line fault", in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/7/2016 12:17:13 PM • Coby TFTV3225 32... • Answered on May 07, 2016
Picture has a grey box over about 80% of screen, then vertical lines take over and we lose the picture
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
10/30/2015 6:04:10 AM • Coby TFTV3225 32... • Answered on Oct 30, 2015
I have a black spot on left side of screen, how can I make it go away?
Dead pixels in the LCD wafer; common issue with LCD televisions as they age. Replace the LCD wafer or consider purchasing a new television.
5/23/2015 10:00:14 PM • Coby TFTV3225 32... • Answered on May 23, 2015
Coby tv wont turn on but has power
unplug it, hold power button for 30 seconds plug it in. does it work? if not test outlet. does outlet work? if so... tv needs repair
2/19/2015 12:02:01 AM • Coby TFTV3225 32... • Answered on Feb 19, 2015
We have a coby tv given to the mission and it starts but shuts itself off.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2/10/2015 11:31:27 AM • Coby TFTV3225 32... • Answered on Feb 10, 2015
2answers
Tv screen went black and will not come back up.
It sounds that the main board to this TV is damaged. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts.
2/6/2015 4:25:19 AM • Coby TFTV3225 32... • Answered on Feb 06, 2015
Coby 42 inch keeps maxing out volume
unfortunately the coby company has gone out of business probably because they have produced an inferior product that has had many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind.
1/24/2015 5:11:55 AM • Coby TFTV3225 32... • Answered on Jan 24, 2015
Coby TFTV3225 32 in. LCD TV will not turn on
if you have tried the remote and manual button on the set and there is power at the wall then a circuit in the set is fried
1/24/2015 4:48:12 AM • Coby TFTV3225 32... • Answered on Jan 24, 2015
No Picture
if the blue light is on then the set is on but there is a problem with a circuit that provides picture
1/24/2015 4:37:31 AM • Coby TFTV3225 32... • Answered on Jan 24, 2015
Is there a reset button on the coby tftv3225
There have not been "reset buttons" in TV's for decades to my knowledge - they were too slow to react in solid state sets, and were expensive to boot. You would be better off in my opinion (after working on TV's since 1976) in buying a better brand of TV. I've had good luck with Vizio for value and reliability. Other brands to consider that I'm familiar with are LG and Samsung, A website that makes comparasions easy has been Best Buy. Just stay away from their knock off brands, and do cross checks with Amazon and others.
7/17/2014 3:04:54 PM • Coby TFTV3225 32... • Answered on Jul 17, 2014
Does anyone else have a problem with the sensor on the tv
which sensor and what issue?
7/5/2014 6:05:40 AM • Coby TFTV3225 32... • Answered on Jul 05, 2014
Coby TFTV3225 32 in. LCD TV Logo
92 questions posted
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Televison & Video
Most Popular Question
black spot or bloch left side screen
  • Televison & Video
