I replaced the Magenta/Cyan ink cartridge twice and still have to with the first, open the door to access the cartridges and shut it and then print, and with the second, shut off the printer and restart, it prints once and then the process has to be repeated. In both cases the Magenta light comes on, the first it blinks and the second it does not. The test prints are excellent showing no problems.
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
SOURCE: printer cartridge's cyan and yellow not printing
replace w/new ink and nozzle check , if test nozzle print ok , if the same happened , head cleaning , test print , all solor solid nothing gap or blank within the color , mean good , try to print variety color picture.
SOURCE: Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck, then i called amazon.com and i ordered a new epson printer,
SOURCE: ink cartridges
Go through your standard print procedure. File>print then look for the properties button which is usually on the top right of the window. Press Properties and look for either Printing in B/W or grey scale. That should prevent your color cartridges from printing. After you check that box, you should be able to print black only.
SOURCE: 932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
