Question about Xerox Phaser® 8860/8860MFP Extended Capacity Maintenance (30,000 Yield)
Xerox Phaser 8860 error 09,005.40:71198
When powering up printer goes to Xerox Phaser 8860 error 09,005.40:71198
Posted by Ed Schray on
officemumbaby
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Officemun (Jarbo Officeworld Ikong) can buy Cheap and same Great quality Ink Cartridge online for all printer brands, Discounts and Low price Ink /Toner cartridges for help reduce your printing costs:
https://www.officemum.com/
10%off code:
OFFICEMUMDWD
Posted on Apr 04, 2018
Smithmkt
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 68 Answers
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number[email protected]@[email protected] anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Xerox Phaser 8860 error 09,005.40:71198 - slide2-l0xu1cdavxhiwuccezmd05t0-5-0_0.jpg
Posted on Apr 24, 2017
garyab9ss
    Novelist:
  • 140 Answers
I found the general information regarding this error code:
9,0XX.4x Ink Loader Faults
An Ink Loader error has occurred.
The following troubleshooting procedure applies to these
errors: This is where it can either be easy or expensive!
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Primary Causes
The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1 9,0xx.4x Troubleshooting Reference Table
Applicable Parts Wiring and Plug/Jack References
Ink Loader Assy, PL 2.0 I/O Board (2/2) - Figure 12
NOTE: Following Ink Loader Assembly replacement, or for Ink count flag stuck errors, clear the
Ink Stick Count (ISC) fault using the Clear ISC Fault menu item located in the Service Diagnos-
tics Function menu.
Check the ink areas for obstructions.
Turn off the printer, wait 30+ minutes for the inks to cool and set so the liquid wax will harden.
Remove the side panels and carefully reseat all connectors on the nvram board
Here are some of the error codes you may see and what they indicate:
9,000.44 The Ink Loader failed during operation.
9,005.49 The Cyan Ink Melt Heater is on, but no ink is detected.
9,006.41 The Magenta Ink Melt Heater is on, but no ink is detected.
9,007.42 The Yellow Ink Melt Heater is on, but no ink is detected.
9,008.43 The Black Ink Melt Heater is on, but no ink is detected.
9,015.41 Ink Loader Door opened to clear Cyan Ink Stick Jam.
9,016.41 Ink Loader Door opened to clear Magenta Ink Stick Jam.
9,017.41 Ink Loader Door opened to clear Yellow Ink Stick Jam.
9,018.41 Ink Loader Door opened to clear Black Ink Stick Jam.
9,025.41 Ink Loader Door opened twice to clear Cyan Ink Stick Jam.
9,026.41 Ink Loader Door opened twice to clear Magenta Ink Stick Jam.
9,027.41 Ink Loader Door opened twice to clear Yellow Ink Stick Jam.
9,028.41 Ink Loader Door opened twice to clear Black Ink Stick Jam.
9,035.41 Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
9,036.41 Ink count flag stuck after melting 2.5 Magenta Ink Sticks.
9,037.41 Ink count flag stuck after melting 2.5 Yellow Ink Sticks.
9,038.41 Ink count flag stuck after melting 2.5 Black Ink Sticks.
I hope that between the reseating of the connectors and clearing the ink paths this issue can be resolved.
Posted on Dec 04, 2014
1 Related Answer
damneddle
damneddle
  • 1607 Answers
SOURCE: Have Xerox Phaser Printer Error 09,008.43:100277.
Try using "PhaserSmart" to automatically diagnose the problem of your printer. You just need to input the IP address while your printer is turned ON.
Phaser SMART
Posted on Sep 18, 2011
I have a phaser 8860 that has stopped and gives a printer error of 09,035.43:65927
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8!9!6!9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Feb 17, 2015 | Xerox Phaser 8860/PP Color Laser Printer...
Error 08,035.42:7417 after power loss. on 8650 phazer
my xerox printer phaser 8860 is stop printing. message show, 08,035.42: 138484. Is this fixable
Apr 05, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8860 printer is displaying 12.1 error message, what does that mean
12 codes on that machine mean a software error.
You can try removing and reseating the RAM chips , most likely its corrupted and will require a software install. The software ( Firmware) would be found at xeox.com, Click on drivers and downloads, then type in 8860 in the search box then click to drivers and downloads again and scroll down to firmware.
Jul 09, 2010 | Xerox Phaser 8860MFP Printer
Phaser 8860 error code 08,030.46;21225
The Media Path Motor Stalled
Solutions ranked by relevance:
Make Sure There is no Paper Trapped in the Paper Path
Power the Printer OFF, Wait 30 Seconds and Then Power ON
Oct 01, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8860
This unit has a common situation that requires parts and 2-3 hours of labor. This error points to a bad process motor 127K53240
These generally go bad with 2 camshafts 020K14800 and 008K02160
Whit
Item, Inc.
Jul 10, 2009 | Xerox Phaser 8560DN Printer
8860 print error 07,010.43;92622
print out comes after restarting the phaser 8860 printer and stops after sometime
Jul 04, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox 8860 stuck in inialize
Sounds more like an NVRAM issue.
May 22, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8860 error code 34,015.48:66749
Hi
Cyan Ink Level Sense Fault (34,015.48)
You must have a minimum of something like 3 ink blocks in each cartridge so it looks like the CYAN is running low. Double check that you have a least 3 in each one and the error should go after a reboot. Please use the link below for any further problems or let me know.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8860),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8860,varset=prodName:Phaser%208860
Mar 20, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser® 8860/8860MFP Extended Capacity Maintenance (30,000 Yield) Logo
271 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
