Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i also noticed that there are only 2 slots for the ink:cyan & magenta please help. many thanks!
Posted by mkdnunez on
Chris Hingee
  • 32,281 Answers
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Posted on Aug 12, 2011
  • Wilma Willey
    Wilma Willey May 23, 2014
    Thanks but the ALPS printers are a whole different animal. There is no designated slot for black.
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Printer is printing yellow instead of red and colour is fade
The magenta has run out (red).
Replace the HP 22 tri-color cartridge.
It probably has yellow and cyan (blue) left in it, and the black is most likely working as well, but if any of the 3 colors in the tricolor cartridge run out, the whole cartridge must be replaced.
For instance, if I printed my vacation photos and there was a lot of water and blue sky in all of them, the cyan might run out long before the cartridge life expectancy.
Also, don't forget that cartridges are rated in pages printed at 5% coverage.
Since a photo is about 25% of a full page, a photo printed at full bleed (edge to edge) will only yield 32 4 X 6 inch photos from a cartridge rated at 160 pages (5X expected coverage = 1/5 the prints)
Mar 27, 2011 | HP DeskJet F380 All-In-One Printer
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
Magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
Colors Murky... HP DeskJet 1120c
REPLACE COLOUR CARTRIGE.IF THE CARTRIDGE IS DAMAGE ON THE INSIDE THE THREE COLOURS SOMETIMES MIX CREATING A COLOUR WHICH LOOKS BLACK
May 11, 2008 | HP DeskJet 1220c InkJet Printer
k24674
