My mother owns a Maytag Neptune Washer model # MAH6500AWW. It has had minimal use for just hereself. Apparently she was never aware that you must constantly clean the rubber boot seal after each wash. I have discovered it is stained black with mold. I am trying to clean with bleach but not sure I will be able to completly remove it. Can this rubber boot seal from the door to the drum be replaced?
YES YOU CAN , CONTACT PLUMBERS SUPPLIRES WITH MODEL NUMBER OF MACHINE AND MAKE FOR BERINGS WHEN YOU HAVE THEM YOU CAN START, FIRST MAKE SURE POWER IS OF THEN LOCATE SKREWS IN THE MACHINE PANEL, REMOVE AND OPEN PANEL LOCATE BEARINGS AND REMOVE BRACKET HOLDING THEM IN AND REPLACE NEW ONES , IF YOU OPEN MACHINE AND HAVE A GOOD LOOK YOU WILL FEEL MORE CONFIDENT, GOOD LUCK.
it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
