Question about Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale
SOURCE: need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
Posted on Jan 22, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Posted on Oct 17, 2009
SOURCE: not sure of model of my lithium scale, it reads
change out the batteries
Posted on Mar 22, 2010
Aug 20, 2014 | Office Equipment & Supplies
Apr 05, 2013 | Escali BFBW200 Body Fat/Water Bath Scale
Jan 07, 2011 | Taylor 5568 Fat Scale Stainless Steel ()
Jul 07, 2010 | Health & Beauty
May 16, 2010 | Microwave Ovens
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Jun 22, 2009 | Taylor & Digital Scale Lithium Scale
Dec 29, 2008 | Nintendo Professor Layton & the Curious...
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
111 people viewed this question
