Question about Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale
Can not change from Kg to Lbs
I cannot change the monitor from showing the weight from Kilogram to Lbs.
Posted by schakamian on
Anonymous
    New Friend:
Flip over the scale, on the back there is a black button, slide it to pounds.
Posted on Apr 05, 2010
ahiw
You can also Convert kilogram to lbs from here
Posted on Sep 03, 2019
Change to lbs from kg
hi Johanna.
go to this link should help you out.
how to change kg to lbs Google Search
Dec 15, 2017 | Health & Beauty
Cannot get it to simply read weight in pounds
Hi dave,
Here is the Simple example of converting weight to pounds.
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Hope it helps.
Thank you for using fixya.
Sep 09, 2011 | Health & Beauty
Convert metric weight to pounds
Good luck.
Apr 22, 2011 | Office Equipment & Supplies
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
How do you change the weight settings from kg to lbs
I don't know if you can change the setting but 1 kg is 2.2046 lbs so 100 kg would be 220.46 lbs for example. Multiply kg times 2.2046 to get lbs
Mar 08, 2009 | Nintendo Wii Fit for Wii
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale Logo
5,092 people viewed this question
Top Taylor Health & Beauty Experts
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
