The round flap at the ice dispensing station will not close all the way when ice has been dispensed. It makes a clicking sound which drives us crazy. The flap is trying to close and seal but will not. In the morning all the ice is melted due to warm air flowing back up the area where the ice comes out.
SOURCE: ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it. 2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
SOURCE: Kenmore - Side by Side condensation in water/ice dispensor area
maker sure your flapper is closing all the way the trim plate will come off its snapped on once you get it strated it will come they are a bear use butter knife to pop it loose on cornor first hope this helps
SOURCE: ice dispenser freezes
check your ice dispenser door flap,is it coming all the way down?there is a solinard that opens and closes it,it might be going bad,if you can get in to it it might just need alittle lube,what make?let me know what you find-mike
SOURCE: Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
