AC unit won't move from 66 degrees. Don't have remote control or the owners manual.
SOURCE: AC not producing cool air
If this is a newer system there will be a freeze sensor. It may be low on refrigerant. I would check the obvious things first. Are the filters and coils free of debris? Finally only set the temperature to your comfortable temp not lower as this can cause freezing too (generally not below 70 degrees)
SOURCE: LG SPLIT SYSTEM AC.
Fixed fault by not only switching off AC unit at power point, had to pull out plug top & lead from wall for one minute. This must allow electronics to reset.
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
SOURCE: we have LG spilt AC
There will be manual butting near the display. Lift the front cover and you can see. But no option to change mode or setting temp. It's strictly advisable to buy new remote.Thanks.
SOURCE: I have a new LG
Reverse or open phase. Check all 3 phases are present and correct. If correct voltage appears at all three phases, swap any two to cure the fault. Thanks. Helpful?
