Question about LG Heating & Cooling
I have a new LG ducted AC unit B62UWYUY81 and geeting error code CH 54 on the remote controller . Can you help to reset the system.
Posted by rajiv218 on
  • Anonymous Mar 16, 2014
    What is error ch 54 lg inerter ac model LTNC368DLE1
    LG cassette unit ac LTNC368DLE1 error ch 54
R Subramaniyam Iyer
  • 2,133 Answers
Reverse or open phase. Check all 3 phases are present and correct. If correct voltage appears at all three phases, swap any two to cure the fault. Thanks. Helpful?
Posted on Feb 12, 2011
Our LG air conditioner is show code CH 01. What does this mean and what's the fix?
The E2 / CH01 error code is an AUTO-STOP PROTECTION error resulting from a short or open circuit in the indoor pipe sensor. The unit will require a repair service. Airbulance AC Repair is always here to help.
Jul 02, 2018 | LG Heating & Cooling
Tip
LG UNIVERSAL SPLIT AIR CONDITIONING FAULT COEDS Error Indicator: # The...
Error Indicator:
# The function provides self-diagnosis and displays an error code if there is any trouble.
# Error codes are displayed on the Indoor unit's Wired Remote as CH**, and/or Fascia Display. In
addition, the code is indicated via LED's on the outdoor unit control board.
# If more than two troubles occur simultaneously, the lower number of error code is displayed first.
# After an error occurs, if error is released, error LED is also released simultaneously
for more check the link bellow
http://electro-medical.blogspot.in/
on May 10, 2015 | LG Heating & Cooling
LG air conditioner model number LMN095HVT units keep on flashing with error code CH 46 and with no response at all. How can I fix it? Thanks for your help in advance!
ERROR CH46:
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Sep 01, 2015 | LG Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Steve Oakes
Steve Oakes
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
