20 Most Recent LG LS-K1830CL Cool Mini Split Air Conditioner Questions & Answers
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
LG LS-K1830CL... | Answered on Jul 02, 2017
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
LG LS-K1830CL... | Answered on Jul 25, 2016
There is no problem the unit is cooling on ly and is not a heat pump so it can't heat.
LG LS-K1830CL... | Answered on May 28, 2015
This is how air conditioners work.
They transfer heat from (usually) hot places to cooler places.
When working in the opposite direction, the machine is attempting to pump heat from the cool place (making it colder) to the warm place (making it warmer).
Flushing the frozen condenser with cold water adds more heat to defrost the condenser, but it will refreeze when you try extracting more heat from the cold place.
LG LS-K1830CL... | Answered on Oct 31, 2014
Hi Emanuel,
Your out door unit could be very dirty or the outdoor unit temperature sensor is out of position.
LG LS-K1830CL... | Answered on May 04, 2014
Dear Friend! Before recharging gas.did you check leak testing? If not, again you will same problem.
And some more reasons for frost up:
1. Indoor coil & air filter dust blocked-clean it. 2.Less rpm of indoor fan motor- replace capacitor or motor.
Thanks, it's helpful to you.
LG LS-K1830CL... | Answered on Sep 24, 2013
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
LG LS-K1830CL... | Answered on May 18, 2013
In Auto mode, and jet cool or fast cool (if option is there in your remote), you can't change speed. Keep cool mode and then press fan again and again still you get required speed. Suppose, as you said beep sound is there when you select speed, check related speed terminal in PCB. If power is there, winding open in motor. If no power, replace/repair PCB. Thanks and hope it's helpful.
LG LS-K1830CL... | Answered on Aug 05, 2012
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
51 questions posted
Top LG Heating & Cooling Experts
Marvin
Marvin
Steve Oakes
Steve Oakes
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
air con mini split gives error code 4
  • Heating & Cooling
