20 Most Recent LG LP1200DXR Portable Air Conditioner Questions & Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset Air Conditioning Tamarac
LG LP1200DXR... | Answered on Aug 15, 2016
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5 kOhm at 25C. If not replace sensor.
LG LP1200DXR... | Answered on Feb 09, 2016
there should be an upper drain and lower drain in the back bottom of the unit unplug the drain plug and voila!!
LG LP1200DXR... | Answered on Sep 09, 2015
Depends on where you live and how much you care about your cat. I wouldn't.
LG LP1200DXR... | Answered on Jun 11, 2015
All air conditioners collect condensate. It has to drain somewhere. Try connecting tubing to the drain hole or port. In order for air conditioners to remove heat from a space, they also remove humidity, which is water vapor in the air. Like placing a cold beverage in a warm room, it will form condensate (water) around it. The water that you were trying to drain out already leaked out. This is a normal thing for condensation to form when cooling. The condensate needs to be emptied regularly or piped with flexible tubing to a window or plumbing.This is the same as water dripping from your car while the A/C is on.
LG LP1200DXR... | Answered on Jun 10, 2015
tip the zircon back a little bit and water will pour our. I did this because i had the same problem. This solves it
LG LP1200DXR... | Answered on Dec 23, 2014
Wrong site for that
Just a chat room
LG LP1200DXR... | Answered on Aug 22, 2014
If it hasnt been drained then there is likely a float switch that is keeping the compressor from running so that it doesnt overflow.
LG LP1200DXR... | Answered on Aug 19, 2014
portable air conditioner need clean condenser .
LG LP1200DXR... | Answered on Jul 16, 2014
Check your fuel filter & purge the pump
LG LP1200DXR... | Answered on Dec 16, 2013
LG LP1200DXR Portable Air Conditioner Logo
85 questions posted
Top LG Heating & Cooling Experts
Marvin
Marvin
Steve Oakes
Steve Oakes
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
safe leave all day no one home like
  • Heating & Cooling
