This happens because of the color decoder in the TV. A TV color decoder has a switch that makes the TV image black and white when the received signal does not have sufficient power. Your TV color decoder switch remains in the black and white position (the TV receives weak signal or the TV color decoder is damaged).
Replace the TV antenna, try an antenna amplifier or a digital receiver before the TV.
Yes. Dave's grandfather was born blind. He was born in 1911 in a white hospital to a white woman. His birth father is unknown. According to Dave on the DVD commentary, "My grandfather looked like a white person. He probably was a white person...His dad was either black or white. Nobody knows. He could be white." He was adopted by a black family and he could not see himself so according to Dave "as far as he knows he's a black dude that grew up in the streets of D.C." On the day of the assassination of Martin Luther King, some black people started riots. According to Dave, on that day his grandfather is on a bus and hears a group of black youths threatening a white man. His grandfather thought how silly the white man was to be in a black neighborhood while blacks were rioting. He did not realize that the white man was him. As his grandfather explained to the youths that he was black, one can imagine the confused looks on their faces.
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Have you tried adjustign the mhz settings ie: change from 50mhz to 60 mhz as some games will show up in black and white if you have the xbox set to 50 mhz
if you have the dvd's s-video plugged in and also something plugged into the yellow video input this will happen , does the piture on the tv show black and white?
otherwise the vcr head is dirty and needs to be cleaned
please rate a fixya and I'll be happy to even assist you further
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
