OKI MICROLINE 280 Elite Matrix Printer Logo
Anonymous Posted on Aug 21, 2013
What should the Dip switches be set to when using a BT via serial port?
1 Related Answer
Anonymous
  • 957 Answers
  • Posted on Aug 02, 2011
SOURCE: the printer Microline 280 elite
I have a link below that can help you with regards the dip switches.
Just click HERE so that you can get to the site
Click HERE as well because this is the description for dip switches
Click HERE because this is the diagram and more explanation of dip switches.
I hope that all the links I gave you can help you resolving the issue.
Thanks.
Phone is displaying DHCP:discovery boot ver 02.01.00.04. Mitel phone was working perfectly until router changed to BT Hub. What can I do to resolve it?
You can download the TNA analyzer to test ports. Or your router is not giving dhcp to the phone. You can try to statically assign an IP address to. The phone.
My zebra 105 se wont print using RS232 serial cable
Make sure the serial dip switch settings match your com port on the computer. You need a null modem cable or adapter.
1helpful
2answers
Our tec b-472 qp only blinks the online green led when a job is sent to the printer but does not print. we have set up printer with proper driver from Toshiba and are using serial cable 25 to 9 pin. Serial...
The serial cable for the Tec printer must be wired straight through (not a crossover cable). Are you using the original cable that came with the printer? Do you still have the manual? there are some dip switches in the top right hand corner of the inside of the printer that control the serial port settings. If you have the manual and look in there check that they are set to default settings.
1helpful
4answers
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
[email protected]
FredP
Serial Settings for the Zebra 105Se
here is manual
http://www.jnc-service.nl/assets/manuals/zebra/S-series.pdf
3answers
We are trying to set up to run locally on a serial port
The serial port parameters are set from the front panel.
Hit the "Setup" button, then hit the "Next" button (many times) until you reach the Serial Port parameters. You'll be prompted for a password before you get there. The default is "1234", entered with the "Plus and Minus" buttons.
Use the "Plus" and "Minus" button to make changes.
When finished, use the "Exit" button. Select "Permanent" changes and hit the "Save" button.
2answers
Problems with e800BT and com ports
I use an e830 with a Holux GR230 without having any problems. The e830 uses already the latest stack from Toshiba so no need to upgrade. For the e800, hm depends on what kind of BT SD card you use, meanwhile Toshiba sells the BT SD3 card. Anyway, I would recommend to use the latest BT stack from Toshiba for your Toshiba BT SD card.
Activesync via bluetooth
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Com port
IR port --> in AS just go to "file\connection settings" then tick in the checkbox "enable connection serial cable or IR to this COM port" and choose from the drop down menu "IR port" BT port --> go to the BT manager on your PC, then "advanced config" and click onn thee nail "local services" - double click on the "BT Serial Port" and you will be prompted to the "properties" window that gives you a drop-down menu where you can choose the # of the COM port. You can also edit numbers in the System REgistry, but this requires proper care. I think the foregoing is sufficient for you
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
