20 Most Recent IBM SureMark Printer TF6 Thermal Label Questions & Answers
Could some1 send me the driver for 4610 suremark
Here is the current driver for the suremark 4610;
FTP
3/24/2019 11:46:26 PM • IBM SureMark... • Answered on Mar 24, 2019
2answers
Driver IBM printer 4610 suremark for windows xp
Hi It can be downloaded from here: Driver Update Software for XP Vista 7 8 Cheers Mike
9/5/2018 11:04:44 AM • IBM SureMark... • Answered on Sep 05, 2018
0answers
Dear expert pos machine(ibm SureOne100 Type :
looks like its running on IBM PC DOS. code page 708 - arabic. https://msdn.microsoft.com/en-us/library/cc195061.aspx however if you are using windows, then you may need an arabic windows, just adding an arabic languge file wont help. IBM PC Dos doesnt have an arabic option. you can download the ibm surepos 100 4613 technical reference manual which is what i did for you. but it no help in that arabic is not an option. research using arabic with DOS. because your keyboard is basically a PC one working in DOS.
10/3/2017 2:36:11 PM • IBM SureMark... • Answered on Oct 03, 2017
2answers
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
5/30/2014 7:11:27 PM • IBM SureMark... • Answered on May 30, 2014
0answers
3answers
I have a IBM pos
change flow control to hardware, slow baud rate down
6/20/2013 7:52:09 PM • IBM SureMark... • Answered on Jun 20, 2013
2answers
Printing only one side
Most likely the small 'roller' on the LHS of the paper feed shaft is missing. This roller engages the metal 'yoke' on the LHS when the printer lid closes and provides a suitable pressure for the paper to contact the thermal head. They break into 2 pieces sometimes and fall away from the shaft. Solution: remove circlip and replace the roller if you can get one. I have them made.
2/4/2013 11:25:06 PM • IBM SureMark... • Answered on Feb 04, 2013
4answers
IBM 4610 suremark receipt printer
Hello all,had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means1 size of paper you are using 80mm2 if you use an IBM software or other:other3 if xon/off or DTR/DSR:hardware4 com speed: 9600baud or 19200baud, 9600That's what I igured out. If you need any more info: [email protected]
10/25/2012 4:07:19 PM • IBM SureMark... • Answered on Oct 25, 2012
2answers
As the tickets print there is a blank line through
Clean the thermal head surface.... If the line is still there, then the driver for the head probably has a shorted device. This will require repair at a shop capable of this work.
11/10/2011 1:46:56 AM • IBM SureMark... • Answered on Nov 10, 2011
2answers
IBM SureMark 4610 USB
you may need a new thermal head
11/10/2011 1:45:22 AM • IBM SureMark... • Answered on Nov 10, 2011
IBM SureMark Printer TF6 Thermal Label Logo
34 questions posted
Top IBM Office Equipment & Supplies Experts
Gary
Gary
Fix It Fast...
Fix It Fast...
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Office Equipment & Supplies
Most Popular Question
driver ibm printer 4610 suremark windows
  • Office Equipment & Supplies
