Samsung T220HD LCD Monitor Logo
Anonymous Posted on Aug 21, 2013
Tv wont switch on - Samsung T220HD LCD Monitor
Futronic tv wont switch on
Try unplgging your TV and then plugging it in again. Mine did that one before and this solved the problem. or......
sounds like the high voltage circuit has gone bad ,now the decision repair or re-place
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
1helpful
My LE32S7 tv wont switch on. red light at
check for dry joints on power pcb, look for leaky caps on same
Tv wont turn on
Power supply problem!!!!!
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
TV WONT WORK
have you check the switch,? cuz sometimes the switch doesn't work.
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
