I HAVE A BROTHER LASER PRINTER HL-5150D
THE PAPER HAS JAMMED- HOW DO I SOLVE THE PROBLEM?
Hello a_bowen1
You can clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Note
Caution
To prevent damage to the printer PAPER JAMMED-PRINTER HL5150D - hl50_046.gifatic electricity, do not touch the electrodes shown below.
Note
If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scattePAPER JAMMED-PRINTER HL5150D - chap0615.gift few printouts. Print a few copies of the test page until the scattering of toner stops.
Caution
After you have just used the printer, some intPAPER JAMMED-PRINTER HL5150D - hl50_058a.giff the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
Caution
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
Good Luck and don't forget to leave a rating based on my solution:
Mark
