I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
Check your TV settings under Caption, odds are someone adjusted the captions to text1 or 2.. the box should go away after you change that to off or std cap.
Check your Closed Captioning settings in the menu. I would bet money you have the "Text" feature enabled. Change it to OFF and you should be all set. I hope this was of some assistance.
Someone has accidentally turned the Close Caption Text mode on. Go into your menu locate the closed caption section and just navigate to turn it off and that's it.... sometimes the remote may have it on there labeled CC.
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
iv'e run into this before, you have closed caption text 1,2,3 or 4 on. this is different than the normal "cc" cation. just go into your menu & turn off closed caption.
