Where I can buy paper tray for canon mp160 in singapore.
SOURCE: canon mp160 printer E5 flashing error?
1) With the printer powered off but connected to a power source, press
the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button
(regardless of order), the printer will move into a service mode.
(Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
SOURCE: Canon Pixma MP160 paper will not feed
try the feed button which is usually on the front of the machine. press once
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
SOURCE: Canon mp160 drivers
Hello all you people just joining us,
If you need the drivers for your Canon MP-160, do this:
Mike
