HP LaserJet 1020 Printer Logo
Posted on Mar 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam I experienced a paper jam in my HP laserjet 1022 with a new compatible Toner. My question is if it is technically possible for a toner to cause a paper jam or it is 100% necessarily the printers fault. Thank you for your assistance, Jose Sales Barcelona, Spain
Anonymous
Level 2:
Sniper:
  • Expert 121 Answers
  • Posted on Mar 25, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
121
Questions
0
Helped
87124
Points
411
A toner certainly can cause a paper jam. However the jam would be located in the area of the cartridge. Easiest way to check is swap the new with the old or a known good toner and see if the problem follows the toner.
hope this helps
My HP printer 1022 laser jet is making black stripes at left corner of the paper
This could happen due to
1. Worn wiper blade
2. Worn Drum
3. Worn PCR
above 3 are inside the toner, if you know how to replace them replace or install a new toner, if the problem still persists you have to check the fuser or contact a technician..
HP1022N laserjet printer there are black specs along the printed page. looks like toner smudges.
toner specs are usually caused by a bad cartridge. If it is a refill, it is possible that the waste toner bin was not emptied when cartridge was refilled. Try different cartridge as your first trouble shooting step.
I ran my HP Laserjet 1022 out of toner and when I insalled a new cartridge It never loaded the toner and does not print.
slap it from back side of printer your problem will be resolved if it persists then check the cairtage holder for broken if it is so then replace the older your problem will be resolved .
1helpful
I have a issue with hp laserjet 1022 having cartridge missing error please provide some needful helps
Hi
Make sure you installed HP toner cartridge for your printer. and Insert is correctly into the printer. Try to use the old toner cartridge and check if this is the problem.
Just replace new toner cartridge and i might solve your problem. Regards
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
2answers
We have a problem in HP LJ MFP 5035 Blank Printing kindly provide solution
It must be a problem of your toner cartridge try to print with new cartridge
1helpful
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Hi sir HP Printer 1022 paper jam problem
turn off you print and remove the toner and remove the jam paper and shake then place the toner back and on the printer then you will now restart you system which you place your printer on it will work like that a
1helpful
The lights on the top are flashing. i dont kno what to do to get it to work
You have a paper jam or you are out of toner.
Change the toner cartridge if no jam is found.
k24674
Grand Canyon Tech
Grand Canyon Tech
