I have an '06 GMC Envoy XL.
The rear air only blues from the top vents and can only be controlled by the front control switch. Apparently the rear controls don't appear to be operational. It's a manual...
The testing procedure is fairly long ,to much to post here . The first test would be to hook up a factory or some other professional type scan tool an check for DTC'S - diagnostic trouble codes .
Auxiliary HVAC Control Module
The auxiliary HVAC control module is a class 2 device that interfaces between the rear seat occupants and the auxiliary HVAC system to maintain auxiliary air temperature and auxiliary air distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all auxiliary HVAC DTCs and settings will be erased from KAM. The auxiliary HVAC control module will perform a recalibration of the electric actuators when commanded with a scan tool or if KAM is lost. This will ensure the actuators are moving with in the calibrated range. During this calibration process the auxiliary blower motor will be disabled for up to 3 minutes.
Do you know what class 2 is ? It is a serial data network for the control modules to talk to each other .
Air Distribution - Auxiliary Control
The auxiliary HVAC system provides ventilation for the rear seat occupants.
The auxiliary mode actuator shares a control circuit with the auxiliary air temperature actuator. The auxiliary mode is controlled by a rotary knob on the auxiliary HVAC control module. If change of position is required for both actuators, then the auxiliary HVAC control module positions the auxiliary air temperature actuator first. All control circuits for the auxiliary actuators are at a low voltage potential until a change of position is required. The module then applies a high voltage potential to the appropriate control circuit, which will rotate the actuator.
Air Speed - Auxiliary
There are two separate controls for the auxiliary HVAC system. There is the front auxiliary blower motor switch and the auxiliary HVAC control module. If the front auxiliary blower motor switch is in any other position than OFF or REAR, then the auxiliary air temperature actuator mimics the set passenger temperature. The auxiliary mode will mimic the primary mode. If the front auxiliary blower motor switch is in the REAR position, then the system will only function with inputs to the auxiliary HVAC control module. If the front auxiliary blower motor switch is in the OFF position, then the auxiliary HVAC control module does not respond to input. The auxiliary HVAC control module can not request A/C operation from the PCM. The rotary blower switch on the auxiliary HVAC control module provides the operator the ability to select several blower speeds. The auxiliary HVAC control module provides a pulse width modulated (PWM) signal to the auxiliary blower motor through the auxiliary blower motor speed control circuit. The auxiliary blower motor changes speed based on the received PWM signal from the auxiliary HVAC control module. Power and ground are provided to the auxiliary blower motor through the battery positive voltage and ground circuits. Power and ground are provided to the auxiliary HVAC control module by the ignition 3 voltage and the ground circuits.
Auxiliary Console Mode Actuator
The auxiliary console mode actuator is a 5 wire bi-directional electric motor that incorporates a feedback potentiometer. Low reference, 5 volt reference, position signal, and two control circuits enable the actuator to operate. The control circuits use either a 0 or 12 volt value to co-ordinate the actuator movement. When the actuator is at rest, both control circuits have a value of 0 volts. In order to move the actuator, the auxiliary HVAC control module grounds one of the control circuits while providing the other with 12 volts. The control module reverses the polarity of the control circuits to move the actuator in the opposite direction. When the actuator shaft rotates, the potentiometer's adjustable contact changes the door position signal between 0-5 volts.
The auxiliary HVAC control module uses a range of 0-255 counts to index the actuator position. The door position signal voltage is converted to a 0-255 count range. When the module sets a commanded, or targeted, value, one of the control circuits is grounded. As the actuator shaft rotates the changing position signal is sent to the module. Once the position signal and the commanded value are the same, the module grounds both control circuits.
Auxiliary Mode Actuator
The auxiliary mode actuator is a 5 wire bi-directional electric motor that incorporates a feedback potentiometer. Low reference, 5 volt reference, position signal, and two control circuits enable the actuator to operate. The control circuits use either a 0 or 12 volt value to co-ordinate the actuator movement. When the actuator is at rest, both control circuits have a value of 0 volts. In order to move the actuator, the auxiliary HVAC control module grounds one of the control circuits while providing the other with 12 volts. The control module reverses the polarity of the control circuits to move the actuator in the opposite direction. When the actuator shaft rotates, the potentiometer's adjustable contact changes the door position signal between 0-5 volts.
It's nice to know how thing's work before trying to fix it .
