20 Most Recent
Rockford Fosgate RFX-9210 CD Player Questions & Answers
Tel mute
The Tel Mute function is controlled by the pink wire in the loom. Make sure it is not connected to anything.
A capacitor inside the unit has also known to cause this problem when it goes bad. This will have to be repaired by a tech. but you can let them know to look for C719 or C711 (I think C711 is printed on the pcb) .
The manual can be downloaded from Rockford website.
How to i take out the radio?
Remove the console/dash cover. It is usually screwed on or clips on depending on year/manufacturer. After that just undo the screws holding it in plac and unplug the wires in the back.
I have an E03 error on my Rockford Fosgate CD player in my Eclipse. Anything I can do without taking into the dreaded dealer?
You must take it to your dealership. I think this may be a problem with the actual player. I am on CD player number 3 (2 times it has "eaten" my CD's without spitting them out, showing the E03 message), and mine about 2 months ago came up again with the E03 message. When I took it in again to the local mitsubishi dealership, the service guy actually had the nerve to ask me if I inserted an "aftermarket CD". I asked him what the heck that was. He explained it was a burned CD. When I told him, no, that it was stuck on a commercial book on CD, he *******. The players are on backorder, which indicates to me that a lot of people are having this problem and they are working to resolve it (if I ever get it). If I don't get mine replaced for free again soon, then I'm going to file a lawsuit over unfit for particular use, especially considering it says Mp3 player on the face of the changer. I find it difficult to believe that it would then eat Mp3 CDs. I think this may just be a factory-wide problem with these, and would love to know if others have the same problem? I know we have other issues with our Eclipse like the paint, etc.
Lost face
If you find a Local Audio dealer and you have your Model number and any other numbers they might need you might be able to get a new one from them. Meaning they would be the ones to get in contact with Rockford. hope that helps
Tel.mute
A capacitor inside the unit has also known to cause this problem when it goes bad. This will have to be repaired by a tech. but you can le tthem know to look for C719 or C711 (I think C711 is printed on the pcb)
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
